[Qgis-user] QGIS SVG: outdated warning
    Matthias Kuhn
    matthias at opengis.ch
    Sat Nov 25 03:42:34 PST 2017
Hi Richard,
In this case I was confused by the term stable in the previous message.
If this is still there on 2.99, can you check if SVG export also works with
* Transparency
* Layer blend modes
IIRC, these were the tricky things.
ThanksĀ  a lot
Matthias
On 11/25/2017 12:31 PM, Richard Duivenvoorde wrote:
> I think Tobias was talking about 2.99. Just tested and msg is indeed
> still there...
> Both (svg and pdf) are working here with a simple colored shape with
> labels with me.
> Regards,
> Richard
> On 25-11-17 12:20, Matthias Kuhn wrote:
>> Hi Tobias,
>> there is no stable release using Qt5 so far. Can you verify with QGIS 2.99?
>> Thanks
>> Matthias
>> On 11/25/2017 09:44 AM, Tobias Wendorff wrote:
>>> Hi there!
>>> I'm on latest QGIS2 (stable). When choosing "SVG export" on map composer,
>>> you'll get this warning:
>>> "The SVG export function in QGIS has several problems due to bugs and
>>> deficiencies in the Qt4 svg code. In particular, there are problems with
>>> layers not being clipped to the map bounding box.
>>> If you require a vector-based output file from Qgis it is suggested that
>>> you try printing to PostScript if the SVG output is not satisfactory."
>>> QGIS2 uses QT5 and there's no PostScript export support anymore ;)
>>> Shall I file this as a GUI bug?
>>> Best regards,
>>> Tobias
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
