[Qgis-user] QGIS SVG: outdated warning
Tobias Wendorff
tobias.wendorff at tu-dortmund.de
Sat Nov 25 05:07:41 PST 2017
Hi Richard,
no, I was talking about QGIS2 (stable), but I was wrong about Qt5,
I'm sorry. I've looked for Qt5 libraries installed only and didn't
check that QGIS2 still uses Qt4. I don't have a clue, why the
installer installed Qt5 anyway.
QGIS2 doesn't have EPS export, does it? I can't find it anymore.
Perhaps I'm looking at the wrong menu again...
Best regards,
Tobias
Am Sa, 25.11.2017, 12:31 schrieb Richard Duivenvoorde:
> I think Tobias was talking about 2.99. Just tested and msg is indeed
> still there...
> Both (svg and pdf) are working here with a simple colored shape with
> labels with me.
> Regards,
> Richard
> On 25-11-17 12:20, Matthias Kuhn wrote:
>> Hi Tobias,
>> there is no stable release using Qt5 so far. Can you verify with QGIS
>> 2.99?
>> Thanks
>> Matthias
>> On 11/25/2017 09:44 AM, Tobias Wendorff wrote:
>>> Hi there!
>>> I'm on latest QGIS2 (stable). When choosing "SVG export" on map
>>> composer,
>>> you'll get this warning:
>>> "The SVG export function in QGIS has several problems due to bugs and
>>> deficiencies in the Qt4 svg code. In particular, there are problems
>>> with
>>> layers not being clipped to the map bounding box.
>>> If you require a vector-based output file from Qgis it is suggested
>>> that
>>> you try printing to PostScript if the SVG output is not satisfactory."
>>> QGIS2 uses QT5 and there's no PostScript export support anymore ;)
>>> Shall I file this as a GUI bug?
>>> Best regards,
>>> Tobias
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
