[Qgis-user] QGIS SVG: outdated warning
Tobias Wendorff
tobias.wendorff at tu-dortmund.de
Sat Nov 25 05:05:51 PST 2017
Hi Matthias,
whoops... I just checked the installer again and Qt4 AND Qt5 are
selected. I just checked for Qt4 last time.
But there's no more EPS export, so the message should be updated.
Best regards,
Tobias
Am Sa, 25.11.2017, 12:20 schrieb Matthias Kuhn:
> Hi Tobias,
> there is no stable release using Qt5 so far. Can you verify with QGIS
> 2.99?
> Thanks
> Matthias
> On 11/25/2017 09:44 AM, Tobias Wendorff wrote:
>> Hi there!
>> I'm on latest QGIS2 (stable). When choosing "SVG export" on map
>> composer,
>> you'll get this warning:
>> "The SVG export function in QGIS has several problems due to bugs and
>> deficiencies in the Qt4 svg code. In particular, there are problems with
>> layers not being clipped to the map bounding box.
>> If you require a vector-based output file from Qgis it is suggested that
>> you try printing to PostScript if the SVG output is not satisfactory."
>> QGIS2 uses QT5 and there's no PostScript export support anymore ;)
>> Shall I file this as a GUI bug?
>> Best regards,
>> Tobias
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
