[Qgis-user] QGIS SVG: outdated warning
Patrick Dunford
enzedrailmaps at gmail.com
Sat Nov 25 06:10:57 PST 2017
It means PDF. I don't recall there ever being a postscript option.
On 26/11/17 02:03, Tobias Wendorff wrote:
> I know, but the message is wrong. Neither there is QT4, nor there
> is EPS export in current QGIS ;)
> Am Sa, 25.11.2017, 10:59 schrieb Patrick Dunford:
>> Vector-based output is available via PDF export.
>> On 25/11/17 21:44, Tobias Wendorff wrote:
>>> Hi there!
>>> I'm on latest QGIS2 (stable). When choosing "SVG export" on map
>>> composer,
>>> you'll get this warning:
>>> "The SVG export function in QGIS has several problems due to bugs and
>>> deficiencies in the Qt4 svg code. In particular, there are problems with
>>> layers not being clipped to the map bounding box.
>>> If you require a vector-based output file from Qgis it is suggested that
>>> you try printing to PostScript if the SVG output is not satisfactory."
>>> QGIS2 uses QT5 and there's no PostScript export support anymore ;)
>>> Shall I file this as a GUI bug?
>>> Best regards,
>>> Tobias
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
