[Qgis-user] QGIS SVG: outdated warning
Tobias Wendorff tobias.wendorff at tu-dortmund.de
Sat Nov 25 05:11:04 PST 2017
Hi there,
even on EPS, PS or PDF, output with effects never really work pretty
well. Some flavors of those types don't accept transparency at all.
Actually, I never wanted to remove  the warning. Please keep the
dialog, just update the message. Perhaps a more neutral warning
should be better, like you suggest.
I just was curious because I didn't find EPS/PS export support at
all and this made me wonder about the dialog's content.
Best regards,
Tobias
Am Sa, 25.11.2017, 13:07 schrieb Richard Duivenvoorde:
> I added some layers, some blending and transparency, but to be honest
> both in 2.x and 3 outcomes (pdf and svg) were more or less ok to me....
> So not sure what it is exactly that I have to do to fail.
> The only difference is that in master I do not get the 'let's print in
> raster...' when printing a pdf.
> So what about: keeping the dialog (as I think at least for SVG the
> outcome will never be what a designer wants (id's, layers as layers etc
> etc), but change the message to: "Both pdf and svg exporting is done via
> the Qt-library. Results can vary based on complexity of (painting) of
> you map, but cannot be influenced by QGIS itself." or so?
> IF in future certain rendertasks appear to screw up either svg or pdf we
> can always add those?
> Regards,
> Richard
> On 25-11-17 12:42, Matthias Kuhn wrote:
>> Hi Richard,
>> In this case I was confused by the term stable in the previous message.
>> If this is still there on 2.99, can you check if SVG export also works
>> with
>> * Transparency
>> * Layer blend modes
>> IIRC, these were the tricky things.
>> ThanksĀ  a lot
>> Matthias
>> On 11/25/2017 12:31 PM, Richard Duivenvoorde wrote:
>>> I think Tobias was talking about 2.99. Just tested and msg is indeed
>>> still there...
>>> Both (svg and pdf) are working here with a simple colored shape with
>>> labels with me.
>>> Regards,
>>> Richard
>>> On 25-11-17 12:20, Matthias Kuhn wrote:
>>>> Hi Tobias,
>>>> there is no stable release using Qt5 so far. Can you verify with QGIS
>>>> 2.99?
>>>> Thanks
>>>> Matthias
>>>> On 11/25/2017 09:44 AM, Tobias Wendorff wrote:
>>>>> Hi there!
>>>>> I'm on latest QGIS2 (stable). When choosing "SVG export" on map
>>>>> composer,
>>>>> you'll get this warning:
>>>>> "The SVG export function in QGIS has several problems due to bugs and
>>>>> deficiencies in the Qt4 svg code. In particular, there are problems
>>>>> with
>>>>> layers not being clipped to the map bounding box.
>>>>> If you require a vector-based output file from Qgis it is suggested
>>>>> that
>>>>> you try printing to PostScript if the SVG output is not
>>>>> satisfactory."
>>>>> QGIS2 uses QT5 and there's no PostScript export support anymore ;)
>>>>> Shall I file this as a GUI bug?
>>>>> Best regards,
>>>>> Tobias
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
