[Qgis-user] Custom Projection in QGIS
Kristian Evers
kreve at sdfe.dk
Thu Nov 30 00:59:07 PST 2017
Hi Chris,
>From your description I have no idea of what you are trying to do. It does however look like the parameters you have is for a 2D Helmert transformation. That is not something you can do in QGIS today. All transformations in QGIS are carried out by PROJ.4. The good news is that in the coming version of PROJ.4 the 2D Helmert is available (as well as a bunch of other geodetic transformations). Eventually this will be available to you in QGIS as well.
/Kristian
Fra: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Franklin, Chris - Perth
Sendt: 30. november 2017 03:47
Til: Qgis-user at lists.osgeo.org
Emne: [Qgis-user] Custom Projection in QGIS
I have been given the parameters for a local grid - it's a version of UTM Zone 29N but I'm not sure where I need to change the syntax
The parameters I have been given are:
rl_correct = -24.273
yd1= 22737.030
xd1= 17332.250
yd2= 25987.560
xd2= 17893.870
ym1= 1193806.320
xm1= 820224.327
ym2= 1196784.417
ym2= 821648.929
Note the Z adjustment
This results in the following transformation
Scale= 1.00801358
Rotation= 15.4548
Shift x= 1171069.29
Shift y= 802891.987
Can someone point me in the right direction as to where these are entered?
+proj=utm +zone=29 +datum=WGS84 +units=m +no_defs
Thanks
Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171130/67a16a1c/attachment.html>
