[Qgis-user] QGIS 3: edit vertices of geometries with exact coordinate values
    Andreas Neumann
    a.neumann at carto.net
    Tue Oct  3 06:36:38 PDT 2017
oh thanks. Wasn't aware about it.
Can I prevent the dialog from being closed all the time? E.g. I would
want the node editor to remain open, also when I select a different
node.
Thanks,
Andreas
On 2017-10-03 15:28, DelazJ wrote:
> Hi Andreas, Right-click with the node tool on a vertex should offer the node editor dialog.
> Regards,
> H.
> 2017-10-03 15:22 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> In QGIS 2.18 there was a panel that listed all vertices of a geometry when activating the node editor tool.
>> In QGIS 3.0, this panel is not available anymore. Is there a replacement?
>> How can I edit vertices with exact coordinates in QGIS 3?
>> Thank you for your hints!
>> Andreas
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user [1]
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user [1]
Links:
[1] https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171003/61b6cf76/attachment.html>
