[Qgis-user] QGIS 3: edit vertices of geometries with exact coordinate values
DelazJ delazj at gmail.com
Tue Oct 3 06:59:28 PDT 2017
Well hidden, isn't it?  Régis taught me too. :)
Not sure you can do that...I'd love too and i thought it'd survive the node
tool refactoring (
https://github.com/qgis/QGIS-Enhancement-Proposals/issues/69#issuecomment-242695414
Harrissou
2017-10-03 15:36 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
> oh thanks. Wasn't aware about it.
> Can I prevent the dialog from being closed all the time? E.g. I would want
> the node editor to remain open, also when I select a different node.
> Thanks,
> Andreas
> On 2017-10-03 15:28, DelazJ wrote:
> Hi Andreas,
> Right-click with the node tool on a vertex should offer the node editor
> dialog.
> Regards,
> H.
> 2017-10-03 15:22 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> In QGIS 2.18 there was a panel that listed all vertices of a geometry
>> when activating the node editor tool.
>> In QGIS 3.0, this panel is not available anymore. Is there a replacement?
>> How can I edit vertices with exact coordinates in QGIS 3?
>> Thank you for your hints!
>> Andreas
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171003/dfbedebf/attachment.html>
