[Qgis-user] QGIS 3: edit vertices of geometries with exact coordinate values
Andreas Neumann
a.neumann at carto.net
Tue Oct 3 07:10:39 PDT 2017
Yes - well hidden.
The other problem is that in the node editor, the selected node isn't
marked/centered in the list of coordinates - this, together with the
immediate closing of the editor, makes the tool not very useful as it
currently stands.
I will open a separate issue in the issue tracker.
Thanks,
Andreas
On 2017-10-03 15:59, DelazJ wrote:
> Well hidden, isn't it? Régis taught me too. :)
> Not sure you can do that...I'd love too and i thought it'd survive the node tool refactoring (https://github.com/qgis/QGIS-Enhancement-Proposals/issues/69#issuecomment-242695414)
> Harrissou
> 2017-10-03 15:36 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
> oh thanks. Wasn't aware about it.
> Can I prevent the dialog from being closed all the time? E.g. I would want the node editor to remain open, also when I select a different node.
> Thanks,
> Andreas
> On 2017-10-03 15:28, DelazJ wrote:
> Hi Andreas, Right-click with the node tool on a vertex should offer the node editor dialog.
> Regards,
> H.
> 2017-10-03 15:22 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
> Hi,
> In QGIS 2.18 there was a panel that listed all vertices of a geometry when activating the node editor tool.
> In QGIS 3.0, this panel is not available anymore. Is there a replacement?
> How can I edit vertices with exact coordinates in QGIS 3?
> Thank you for your hints!
> Andreas
> Qgis-user mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user [1]
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user [1]
Links:
[1] https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171003/86ec26ac/attachment.html>
