[Qgis-user] Fw: Error Message: Adding own script to menu
DelazJ
delazj at gmail.com
Sat Oct 7 09:28:16 PDT 2017
Hi Pat,
I just give it a try with 2.18.13 and it works pretty well as you can see
in the attached image.
All i had to do is:
- go to Processing menu -->Options --> Menus --> Scripts
- expand the script that i'm interested in
- and in Menu Path, write the menu I wanted; if what you wrote does not
exist, QGIS will create a new menu. In my example i just wrote Rastery
You can also add your tools to the "Processing Algorithms" toolbar.
Hope that helps,
Harrissou
2017-10-06 14:59 GMT+02:00 Pat Hin <phi73 at gmx.de>:
> Hello,
> just for group. i "fixed" it by removing all the path to GRASS
> so the error message doesnt appear anymore.
> However i still NOT have managed it to add my own script to the menu or
> better as
> a own button in menu :)
> Maybe somebody in the group has a hint for me ;-)
> thx
> pat
> *Gesendet:* Freitag, 06. Oktober 2017 um 08:39 Uhr
> *Von:* "Pat Hin" <phi73 at gmx.de>
> *An:* "qgis-userlists.osgeo.org" <qgis-user at lists.osgeo.org>
> *Betreff:* Error Message: Adding own script to menu
> Hello
> i tried to add my own script to the main menu of QGIS 2.18.13 and got the
> attached error message.
> As it seems i have not installed GRASS and due all my developments and
> test run well never needed.
> So what do i have to do to fully disable it so that i dont need it anymore?
> thank you
> pat
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171007/5e2b240e/attachment.html>
Name: Capture du 2017-10-07 18-03-01.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171007/5e2b240e/attachment.png>
