[Qgis-user] ubuntugis-nightly: No providers for GRASS and SAGA in Processing?
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Tue Oct 10 11:35:50 PDT 2017
Hi Patrick,
set up a VM with zesty and QGIS 2.99 from the debian-nightly repository
WITHOUT ubuntugis.
And ... tada ... no GRASS nor SAGA algos in processing again.
So in which way is this a solution?
Cheers
Bernd
Am 28.09.2017, 10:39 Uhr, schrieb Patrick Dunford
<blackwhitekez at gmail.com>:
> It's simply that you can eliminate the ubuntugis dependency as a later
> release of Ubuntu does not require it. Running Qgis in a Vm is also a
> viable option if you can't change the OS on your computer. I run Qgis
> now in VMs because I can doe 100% of the things that I could do natively
> and I have drawn hundreds of kilometres of production maps with the
> development masters running in Virtualbox desktop VMs.
> On 28/09/17 20:19, Bernd Vogelgesang wrote
>> Hi Pattrick,
>> sorry, but I do not understand what you are talking about.
>> I'm running the nightlies of the development version and have the
>> ubuntugis-unstable ppa activated.
>> GRASS and SAGA are present in the ppa and are running individually
>> without a problem. They are just not available through QGIS processing.
>> As the nightlies are built frequently, any changes on ubuntugis should
>> be adopted to within a short time. But there are still no providers for
>> GRASS and SAGA.
>> What does this have to do with the version of my OS? All necessary
>> sources derive directly from qgis.org or ubuntugis-unstable, as far as
>> I can see.
>> Cheers
>> Bernd
>> Am 27.09.2017, 23:12 Uhr, schrieb Patrick Dunford
>>> you can run masters up to 313ec55 (January 2017) without ubuntugis on
>>> xenial, I use this one all the time as it is stable and reliable while
>>> I am waiting for some bugs to be fixed in latest masters.
>>> I can see your problem if you want to use the latest master though.
>>> Mostly I take that option to avoid having to convert my project files
>>> back to 2.18 having been doing my real life projects on 2.99 since it
>>> first came out.
>>> On 28/09/17 09:57, Patrick Dunford wrote:
>>>> Another thread we just talked about this, it's an issue with the
>>>> units not being available in ubuntugis yet
>>>> Only xenial and older require ubuntugis for the latest versions, if
>>>> you are running 16.10 or later, or a later debian, these issues don't
>>>> occur.
>>>> On 28/09/17 04:14, Bernd Vogelgesang wrote:
>>>>> Hi,
>>>>> just installed the development version on Ubuntu xenial from
>>>>> ubuntugis-nightly repository.
>>>>> In processing, there are only the qgis algos, but no grass nor saga.
>>>>> In the settings, there is nothing shown about them.
>>>>> Do I miss sth, or are the other providers not included yet?
>>>>> Cheers
>>>>> Bernd
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
