[Qgis-user] Field-dependent feature style or label
knussear knussear at mac.com
Tue Oct 10 10:24:44 PDT 2017
Under the properties for the layer choose "style". In the drop down at the
top choose "rule based". Add rules using the + sign at the bottom of the
white box. When you chose filter edit using ... and a field calculation
dialogue will pop up, build a formula using fields and values, select your
field "Check" , and create the expression "Check" = 1 (or whatever your
value is), create a second rule with different symbology for nulls using
"Check" IS NULL.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
