[Qgis-user] ubuntugis-nightly: No providers for GRASS and SAGA in Processing?
Patrick Dunford blackwhitekez at gmail.com
Tue Oct 10 20:08:16 PDT 2017
That isn't the experience I have had. The only variant of Ubuntu that
wouldn't load GRASS I have seen was 16.04 with 2.18.13
On 11/10/17 07:35, Bernd Vogelgesang wrote:
> Hi Patrick,
> set up a VM with zesty and QGIS 2.99 from the debian-nightly
> repository WITHOUT ubuntugis.
> And ... tada ... no GRASS nor SAGA algos in processing again.
> So in which way is this a solution?
> Cheers
> Bernd
> Am 28.09.2017, 10:39 Uhr, schrieb Patrick Dunford
> <blackwhitekez at gmail.com>:
>> It's simply that you can eliminate the ubuntugis dependency as a
>> later release of Ubuntu does not require it. Running Qgis in a Vm is
>> also a viable option if you can't change the OS on your computer. I
>> run Qgis now in VMs because I can doe 100% of the things that I could
>> do natively and I have drawn hundreds of kilometres of production
>> maps with the development masters running in Virtualbox desktop VMs.
>> On 28/09/17 20:19, Bernd Vogelgesang wrote
>>> Hi Pattrick,
>>> sorry, but I do not understand what you are talking about.
>>> I'm running the nightlies of the development version and have the
>>> ubuntugis-unstable ppa activated.
>>> GRASS and SAGA are present in the ppa and are running individually
>>> without a problem. They are just not available through QGIS processing.
>>> As the nightlies are built frequently, any changes on ubuntugis
>>> should be adopted to within a short time. But there are still no
>>> providers for GRASS and SAGA.
>>> What does this have to do with the version of my OS? All necessary
>>> sources derive directly from qgis.org or ubuntugis-unstable, as far
>>> as I can see.
>>> Cheers
>>> Bernd
>>> Am 27.09.2017, 23:12 Uhr, schrieb Patrick Dunford
>>>> you can run masters up to 313ec55 (January 2017) without ubuntugis
>>>> on xenial, I use this one all the time as it is stable and reliable
>>>> while I am waiting for some bugs to be fixed in latest masters.
>>>> I can see your problem if you want to use the latest master though.
>>>> Mostly I take that option to avoid having to convert my project
>>>> files back to 2.18 having been doing my real life projects on 2.99
>>>> since it first came out.
>>>> On 28/09/17 09:57, Patrick Dunford wrote:
>>>>> Another thread we just talked about this, it's an issue with the
>>>>> units not being available in ubuntugis yet
>>>>> Only xenial and older require ubuntugis for the latest versions,
>>>>> if you are running 16.10 or later, or a later debian, these issues
>>>>> don't occur.
>>>>> On 28/09/17 04:14, Bernd Vogelgesang wrote:
>>>>>> Hi,
>>>>>> just installed the development version on Ubuntu xenial from
>>>>>> ubuntugis-nightly repository.
>>>>>> In processing, there are only the qgis algos, but no grass nor
>>>>>> saga. In the settings, there is nothing shown about them.
>>>>>> Do I miss sth, or are the other providers not included yet?
>>>>>> Cheers
>>>>>> Bernd
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
