[Qgis-user] ubuntugis-nightly: No providers for GRASS and SAGA in Processing?
Patrick Dunford blackwhitekez at gmail.com
Tue Oct 10 20:27:05 PDT 2017
GRASS7 is listed as a provider in my 17.04 VM running master build 655f121.
Are you using the ubuntugis version of master, the suggestion was based
on the known issue with ubuntugis libraries not being updated at the
same time as a new release of 2.18 comes out. If anything this is
probably even more of an issue with nightly builds of master.
The solution is simply based on being able (potentially) to eliminate
the need to use the ubuntugis repository whatsoever. If you can then use
the non-ubuntugis version of master.
On 11/10/17 07:35, Bernd Vogelgesang wrote:
> Hi Patrick,
> set up a VM with zesty and QGIS 2.99 from the debian-nightly
> repository WITHOUT ubuntugis.
> And ... tada ... no GRASS nor SAGA algos in processing again.
> So in which way is this a solution?
> Cheers
> Bernd
> Am 28.09.2017, 10:39 Uhr, schrieb Patrick Dunford
> <blackwhitekez at gmail.com>:
>> It's simply that you can eliminate the ubuntugis dependency as a
>> later release of Ubuntu does not require it. Running Qgis in a Vm is
>> also a viable option if you can't change the OS on your computer. I
>> run Qgis now in VMs because I can doe 100% of the things that I could
>> do natively and I have drawn hundreds of kilometres of production
>> maps with the development masters running in Virtualbox desktop VMs.
>> On 28/09/17 20:19, Bernd Vogelgesang wrote
>>> Hi Pattrick,
>>> sorry, but I do not understand what you are talking about.
>>> I'm running the nightlies of the development version and have the
>>> ubuntugis-unstable ppa activated.
>>> GRASS and SAGA are present in the ppa and are running individually
>>> without a problem. They are just not available through QGIS processing.
>>> As the nightlies are built frequently, any changes on ubuntugis
>>> should be adopted to within a short time. But there are still no
>>> providers for GRASS and SAGA.
>>> What does this have to do with the version of my OS? All necessary
>>> sources derive directly from qgis.org or ubuntugis-unstable, as far
>>> as I can see.
>>> Cheers
>>> Bernd
>>> Am 27.09.2017, 23:12 Uhr, schrieb Patrick Dunford
>>>> you can run masters up to 313ec55 (January 2017) without ubuntugis
>>>> on xenial, I use this one all the time as it is stable and reliable
>>>> while I am waiting for some bugs to be fixed in latest masters.
>>>> I can see your problem if you want to use the latest master though.
>>>> Mostly I take that option to avoid having to convert my project
>>>> files back to 2.18 having been doing my real life projects on 2.99
>>>> since it first came out.
>>>> On 28/09/17 09:57, Patrick Dunford wrote:
>>>>> Another thread we just talked about this, it's an issue with the
>>>>> units not being available in ubuntugis yet
>>>>> Only xenial and older require ubuntugis for the latest versions,
>>>>> if you are running 16.10 or later, or a later debian, these issues
>>>>> don't occur.
>>>>> On 28/09/17 04:14, Bernd Vogelgesang wrote:
>>>>>> Hi,
>>>>>> just installed the development version on Ubuntu xenial from
>>>>>> ubuntugis-nightly repository.
>>>>>> In processing, there are only the qgis algos, but no grass nor
>>>>>> saga. In the settings, there is nothing shown about them.
>>>>>> Do I miss sth, or are the other providers not included yet?
>>>>>> Cheers
>>>>>> Bernd
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
