[Qgis-user] GRASS plugin
    Siwei He
    hesiweide at gmail.com
    Wed Oct 11 20:53:26 PDT 2017
Since I am running Linux mint, it is Ubuntu 16.04 or older. Is that
possible to have a solution on this issue.
Thanks,
Siwei
On Wed, Oct 11, 2017 at 1:42 PM, Patrick Dunford <blackwhitekez at gmail.com>
wrote:
> Grass plugin can be affected by use of Ubuntugis if you are running Ubuntu
> 16.04 or older. Later versions of Ubuntu don't require Ubuntigis to run the
> Grass plugin.
> On 12/10/17 06:32, Siwei wrote:
>> Dear all,
>> Do you have any solution on how to load GRASS data in QGIS? Before, I
>> need to install GRASS plugin to load GRASS data. However, I cannot find the
>> plugin in the version 2.14.19 and 2.18.3 now. Do you have any suggestions
>> on how to load GRASS data directly QGIS now? Thanks.
>> Best,
>> Siwei
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171011/5ea65611/attachment.html>
