[Qgis-user] GRASS plugin
Patrick Dunford blackwhitekez at gmail.com
Wed Oct 11 12:42:31 PDT 2017
Grass plugin can be affected by use of Ubuntugis if you are running
Ubuntu 16.04 or older. Later versions of Ubuntu don't require Ubuntigis
to run the Grass plugin.
On 12/10/17 06:32, Siwei wrote:
> Dear all,
> Do you have any solution on how to load GRASS data in QGIS? Before, I
> need to install GRASS plugin to load GRASS data. However, I cannot
> find the plugin in the version 2.14.19 and 2.18.3 now. Do you have any
> suggestions on how to load GRASS data directly QGIS now? Thanks.
> Best,
> Siwei
> Qgis-user mailing list
