[Qgis-user] Browser Panel Import
Martin Bain Martin.Bain at lismore.nsw.gov.au
Mon Sep 4 23:39:34 PDT 2017
Hi List,
I just discovered a brutal feature of the Browser Panel.
When browsing SQL Server if you happen to click and drag on a table then when you release the mouse button a dialog box will pop up saying "Import Competed".
The table under the cursor when mouse button is released gets overwritten with an empty table, without any sort of prompt!
Within SQL Server I have now revoked DDL permissions from the user that did this (and myself).
But was wondering, Is there a way to prevent or modify this behaviour in QGIS?
Thanks,
Martin.
This email is intended for the named recipient only.  The information it contains may be confidential.  If you are not the intended recipient you must not reproduce or distribute any part of this email, disclose its contents to any other party or take any action in reliance on it.  If you have received this email in error, please contact the sender immediately and delete the message.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170905/e769e7ea/attachment.html>
