[Qgis-user] Browser Panel Import
Martin Bain Martin.Bain at lismore.nsw.gov.au
Wed Sep 6 15:12:59 PDT 2017
Thank you Alessandro and Richard for your replies, I didn’t know what the expected behaviour was.
Thank you Steven for alerting me to the already logged ticket.
From: Steven Evans [mailto:steven.evans at parkes.nsw.gov.au]
Sent: Wednesday, 6 September 2017 8:55 AM
To: Alessandro Pasotti <apasotti at gmail.com>; Richard Duivenvoorde <richard at duif.net>; Martin Bain <Martin.Bain at lismore.nsw.gov.au>
Cc: qgis-user at lists.osgeo.org; Shaun Goodenough <Shaun.Goodenough at lismore.nsw.gov.au>
Subject: RE: [Qgis-user] Browser Panel Import
Hi;
An issues log has been created a couple of months ago.
https://issues.qgis.org/issues/16805
I too fell for the same trap…
I'm encouraging my end users to stick to double click not drag-drop until this can be resolved…
Regards
Steve
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Alessandro Pasotti
Sent: Tuesday, 5 September 2017 7:33 PM
To: Richard Duivenvoorde
Cc: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>; Shaun Goodenough
Subject: Re: [Qgis-user] Browser Panel Import
On Tue, Sep 5, 2017 at 9:14 AM, Richard Duivenvoorde <rdmailings at duif.net<mailto:rdmailings at duif.net>> wrote:
While it's nice to impress new users to use this 'drag a file into a
database' feature :-) .... I think it's also a 'shoot and run' solution:
either OK or nothing...
Would it be an idea to (sorry dialog haters) have a summary/confirmation
dialog in between this action? Telling the user that 'this file/table
with such columns be copied/moved to that file/table with these columns'?
In this case, it would also have made it possible to stop this overwrite
action?
I don't think it's a good design: if the result of the action is reversible a confirm dialog is unnecessary, and we are trying to elminate all unnecessary modals.
I'd stick to the confirm dialog for all potentially destructive actions.
I recommend to follow the new geopackage implementation behavior:
- if the drop is on self: abort
- if the drop overrides an existing table: confirm
- if the drop does not override and hence creates a new table: notify on success or error
If you've done a wrong drop, you can easily delete the imported layer (at least now it's implemented for geopackage and all ogr/gdal, provided it's supported by the gdal/ogr provider)
Regards.
Regards,
On 05-09-17 09<tel:05-09-17%2009>:04, Alessandro Pasotti wrote:
> It looks like a bug.
> Did you file a ticket?
> The expected behavior is that the layer you are dragging is imported
> (without overwriting!) into the destination DB (the drop target).
> In case of overwriting, a confirm dialog should appear.
> I've recently worked on that for geopackage and I've also added some
> logic to prevent dropping onto itself (that could lead to data loss).
> Cheers
> On Tue, Sep 5, 2017 at 8:39 AM, Martin Bain
> <Martin.Bain at lismore.nsw.gov.au<mailto:Martin.Bain at lismore.nsw.gov.au> <mailto:Martin.Bain at lismore.nsw.gov.au<mailto:Martin.Bain at lismore.nsw.gov.au>>>
> wrote:
>     Hi List,____
>     I just discovered a brutal feature of the Browser Panel.____
>     __ __
>     When browsing SQL Server if you happen to click and drag on a table
>     then when you release the mouse button a dialog box will pop up
>     saying “Import Competed”.____
>     __ __
>     The table under the cursor when mouse button is released gets
>     overwritten with an empty table, without any sort of prompt!____
>     __ __
>     Within SQL Server I have now revoked DDL permissions from the user
>     that did this (and myself).____
>     __ __
>     But was wondering, Is there a way to prevent or modify this
>     behaviour in QGIS?____
>     __ __
>     Thanks,____
>     Martin.____
>     This email is intended for the named recipient only. The information
>     it contains may be confidential. If you are not the intended
>     recipient you must not reproduce or distribute any part of this
>     email, disclose its contents to any other party or take any action
>     in reliance on it. If you have received this email in error, please
>     contact the sender immediately and delete the message.
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org> <mailto:Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> w3:   www.itopen.it<http://www.itopen.it> <http://www.itopen.it>
Alessandro Pasotti
This email is intended for the named recipient only.  The information it contains may be confidential.  If you are not the intended recipient you must not reproduce or distribute any part of this email, disclose its contents to any other party or take any action in reliance on it.  If you have received this email in error, please contact the sender immediately and delete the message.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170906/4e2836a1/attachment.html>
