[Qgis-user] Exporting Raster layer to text file
Matt Boyd
mattslists at gmail.com
Fri Sep 15 00:24:14 PDT 2017
Hi David,
rasters come in a few different flavours.
RGB/greyscale photographic type images such as an aerial photograph or a
georeferenced scan of a map are one. There's not a lot of point exporting
those as text.
There are also Raster images where the RGB / black bands represent a
frequency or attribute from a satellite or remote sensing instrument, you
might want to convert those to a different format to use in a different
package or just select a single band to work on.
Single band raster such as grids or DEMS are another type of raster.
The last 2 types above can be saved in alternate formats under the "convert
format" option in the raster dropdown options somewhere, can't remember the
exact name.
I usually do this with grids / single band rasters. the command line option
is gdaltranslate. "save as" doesn't work the same way it does as with
vector data.
I don't have QGIS open at the so I can't recommend a format but I think CSV
is one of them.
Good luck
Matt
On Wed, Sep 13, 2017 at 3:45 PM, David Reid <davidreid6363 at gmail.com> wrote:
> Hello qgis users,
> I am very new to qgis and would like information on how to export raster
> data as a text file.
> Cheers
> David Reid
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170915/364ecca2/attachment.html>
