[Qgis-user] Exporting Raster layer to text file
Matt Boyd mattslists at gmail.com
Fri Sep 15 00:28:08 PDT 2017
David,
also you may find that even though you select a different format it only
saves as a tiff. If you look at the box that states the command line
gdaltranslate is using, the -o flag is the output format. You can check the
box next to the command line and change that manually if it doesn't change
to tiff automatically. Think it's a bug. the output format options can be
googled "-o zmap" works.
On Fri, Sep 15, 2017 at 5:24 PM, Matt Boyd <mattslists at gmail.com> wrote:
> Hi David,
> rasters come in a few different flavours.
> RGB/greyscale photographic type images such as an aerial photograph or a
> georeferenced scan of a map are one. There's not a lot of point exporting
> those as text.
> There are also Raster images where the RGB / black bands represent a
> frequency or attribute from a satellite or remote sensing instrument, you
> might want to convert those to a different format to use in a different
> package or just select a single band to work on.
> Single band raster such as grids or DEMS are another type of raster.
> The last 2 types above can be saved in alternate formats under the
> "convert format" option in the raster dropdown options somewhere, can't
> remember the exact name.
> I usually do this with grids / single band rasters. the command line
> option is gdaltranslate. "save as" doesn't work the same way it does as
> with vector data.
> I don't have QGIS open at the so I can't recommend a format but I think
> CSV is one of them.
> Good luck
> Matt
> On Wed, Sep 13, 2017 at 3:45 PM, David Reid <davidreid6363 at gmail.com>
> wrote:
>> Hello qgis users,
>> I am very new to qgis and would like information on how to export raster
>> data as a text file.
>> Cheers
>> David Reid
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170915/fbe916df/attachment.html>
