[Qgis-user] Convert 3d polyline to 2d QGIS while retaining Z value in your Attributes table
Andreas Neumann
a.neumann at carto.net
Fri Sep 15 07:50:50 PDT 2017
Hi Eddisson?
Which z value? In your example you have different z-values attached to
vertices, but you can only hold a single z-value per record.
There are expressions like z(feature) that work on points, and there are
expressions like point_n(LineStringGeom) to access a certain node. With
this, you could say extract the z-values of the first node of a feature.
Getting an aggregate (say mean z-value) of all nodes would be more
complex and I am not sure if it can be done without Python.
Andreas
On 15.09.2017 16:37, Eddison Araya wrote:
> Hello! a pleasure to greet Do you know how to convert a 3d polyline
> shapefile to a 2D and keep the Z value in your attribute table? Thank you
> Imágenes integradas 1
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170915/8fd93b07/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170915/8fd93b07/attachment.png>
