[Qgis-user] Imported KML files loses format (e.g. colour coding and line size)
    Patrick Dunford
    blackwhitekez at gmail.com
    Sun Sep 17 17:56:56 PDT 2017
Hi Winsome
Good to see another user in Chch :)
I think this is true pretty much with any layer you bring in, you would
find the same if you add any shapefile for example.
You can store the paths when imported into different shapefiles and then
set a style per shapefile, or multiple styles are possible in one
shapefile using style rules.
On 18/09/17 11:20, Winsome Marshall wrote:
> Hi,
> I am a new user and am using QGIS Desktop version 2.18.12. I have a
> kml file I have created in Google earth containing lines of various
> lengths, thickness and colour. My problem is that when I import into
> QGIS (using add vector layer) it only imports the lines and not the
> thickness or the colour. I have used a free trial of ARCGIS to import
> this file without any problems, so I’m not sure why it would be an
> issue with this program.
> Best regards,
> Winsome Marshall
> ph: (03)366 4070
> left cropped logo 80% reduction
> Aquatic Ecology Limited
> Unit 1/454 Madras Street
> Christchurch 8014
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170918/b09c6a93/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170918/b09c6a93/attachment.jpg>
