[Qgis-user] Imported KML files loses format (e.g. colour coding and line size)
Winsome Marshall
winsome at ael.org.nz
Mon Sep 18 17:22:22 PDT 2017
Hi Patrick,
Thanks for your answer! That's quite annoying though, I assumed because I
could import it directly into ArcGIS without any problems I would be able to
with this program as well. I guess I'll just have to go with it!
In reply,
Winsome Marshall
ph: (03)366 4070
left cropped logo 80% reduction
Aquatic Ecology Limited
Unit 1/454 Madras Street
Christchurch 8014
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of
Patrick Dunford
Sent: Monday, 18 September 2017 12:57 p.m.
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Imported KML files loses format (e.g. colour coding
and line size)
Hi Winsome
Good to see another user in Chch :)
I think this is true pretty much with any layer you bring in, you would find
the same if you add any shapefile for example.
You can store the paths when imported into different shapefiles and then set
a style per shapefile, or multiple styles are possible in one shapefile
using style rules.
On 18/09/17 11:20, Winsome Marshall wrote:
I am a new user and am using QGIS Desktop version 2.18.12. I have a kml file
I have created in Google earth containing lines of various lengths,
thickness and colour. My problem is that when I import into QGIS (using add
vector layer) it only imports the lines and not the thickness or the colour.
I have used a free trial of ARCGIS to import this file without any problems,
so I'm not sure why it would be an issue with this program.
Best regards,
Winsome Marshall
ph: (03)366 4070
left
Christchurch 8014
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170919/0d942613/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170919/0d942613/attachment.jpg>
