[Qgis-user] Building QGIS >= 2.18.12 on Linux Mint 18.2 Sonya - with Oracle provider?
Greg Stef gregstef0 at gmail.com
Tue Sep 19 03:17:21 PDT 2017
Hello everyone.
This is my 1st post and I am not sure if it should be short or more
detailed. I have posted a question to Stackexchange (
https://gis.stackexchange.com/questions/255565/building-qgis-2-18-12-on-linux-mint-18-2-sonya-with-oracle-provider),
with no answers so far, so I'll provide the most essential details here,
unless told otherwise.
I was trying to build QGIS on Linux Mint 18.2 (Sonya), in order to have the
Oracle provider - my setup is at the end of this message.
I tried to follow the instructions in
https://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc11
, specifically 3.1 - 3.7 (3.8 seems to be a separate process, which I also
tried and failed) - in 3.3 I used the build dependencies for xenial.
Since this official guide doesn't mention Oracle at all (as if nobody uses
it!),  I searched and tried to use a process like
https://lists.osgeo.org/pipermail/qgis-developer/2014-August/034230.html.
My command was:
ccmake -DWITH_QWTPOLAR=OFF -DCMAKE_BUILD_TYPE=Debug
-DCMAKE_INSTALL_PREFIX=/home/ME/apps/qgis/master -DWITH_ORACLE=TRUE
-DOCI_INCLUDE_DIR=/home/ME/instantclient_12_2/sdk/include
-DOCI_LIBRARY=/home/ME/instantclient_12_2/libclntsh.so.12.1 ..
make -j8
It failed (my 1st attempt in compiling, too).
Before going around asking questions, I thought it prudent to assure the
basics, so I tried to build the 'vanilla way', i.e. from the source as I
download it, without Oracle, without any changes in the process. I made
LD_LIBRARY_PATH null and issued:
-DCMAKE_INSTALL_PREFIX=/home/ME/apps/qgis/master ..
make -j8
After about 15',  I got:
    [ 99%] Building CXX object
src/plugins/grass/7/CMakeFiles/grassplugin7.dir/__/qtermwidget/moc_kptyprocess.cpp.o
src/plugins/grass/7/CMakeFiles/grassplugin7.dir/__/qtermwidget/moc_qtermwidget.cpp.o
src/plugins/grass/7/CMakeFiles/grassplugin7.dir/qrc_qgsgrass_plugin.cpp.o
    Scanning dependencies of target translations
    [ 99%] Generating ../output/i18n/qgis_ar.qm
    [ 99%] Generating ../output/i18n/qgis_bg.qm
    [ 99%] Generating ../output/i18n/qgis_bs.qm
    [ 99%] Generating ../output/i18n/qgis_ca.qm
    [ 99%] Generating ../output/i18n/qgis_cs.qm
    [ 99%] Generating ../output/i18n/qgis_da.qm
    [ 99%] Generating ../output/i18n/qgis_de.qm
    [ 99%] Linking CXX shared module
../../../../output/lib/qgis/plugins/libgrassplugin7.so
    [ 99%] Built target grassplugin7
    [ 99%] Generating ../output/i18n/qgis_el.qm
where it remained frozen, with 100% cpu, for > 20h.
Next day, whet I interrupted the process, I got
i18n/CMakeFiles/translations.dir/build.make:97: recipe for target
'output/i18n/qgis_ar.qm' failed
make[2]: *** [output/i18n/qgis_ar.qm] Interrupt
i18n/CMakeFiles/translations.dir/build.make:105: recipe for target
'output/i18n/qgis_bs.qm' failed
make[2]: *** [output/i18n/qgis_bs.qm] Interrupt
i18n/CMakeFiles/translations.dir/build.make:109: recipe for target
'output/i18n/qgis_ca.qm' failed
make[2]: *** [output/i18n/qgis_ca.qm] Interrupt
i18n/CMakeFiles/translations.dir/build.make:117: recipe for target
'output/i18n/qgis_da.qm' failed
make[2]: *** [output/i18n/qgis_da.qm] Interrupt
i18n/CMakeFiles/translations.dir/build.make:121: recipe for target
'output/i18n/qgis_de.qm' failed
make[2]: *** [output/i18n/qgis_de.qm] Interrupt
i18n/CMakeFiles/translations.dir/build.make:125: recipe for target
'output/i18n/qgis_el.qm' failed
make[2]: *** [output/i18n/qgis_el.qm] Interrupt
i18n/CMakeFiles/translations.dir/build.make:113: recipe for target
'output/i18n/qgis_cs.qm' failed
make[2]: *** [output/i18n/qgis_cs.qm] Interrupt
i18n/CMakeFiles/translations.dir/build.make:101: recipe for target
'output/i18n/qgis_bg.qm' failed
make[2]: *** [output/i18n/qgis_bg.qm] Interrupt
CMakeFiles/Makefile2:4155: recipe for target
'i18n/CMakeFiles/translations.dir/all' failed
make[1]: *** [i18n/CMakeFiles/translations.dir/all] Interrupt
Makefile:160: recipe for target 'all' failed
make: *** [all] Interrupt
I find it *very* frustrating (to put it mildly) that a gis user who chose
Linux as his OS,  must go through all these hoops to get Oracle support -
or switch to Windoze.
My last hope is to all you out there.
Thanks in advance
Greg
My setup:
uname -a
Linux GIS81 4.10.0-33-generic #37~16.04.1-Ubuntu SMP Fri Aug 11
14:07:24 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID: LinuxMint
Description: Linux Mint 18.2 Sonya
Release: 18.2
Codename: sonya
echo $LD_LIBRARY_PATH
/home/<ME>/instantclient_12_2:/home/<ME>/instantclient_12_2/libclntsh.so.12.1:
echo $PATH
/home/<ME>/instantclient_12_2:/home/<ME>/bin:/home/<ME>/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
locale
LANG=en_GB.UTF-8
LANGUAGE=en_GB
LC_CTYPE="en_GB.UTF-8"
LC_NUMERIC=el_GR.UTF-8
LC_TIME=en_GB.UTF-8
LC_COLLATE="en_GB.UTF-8"
LC_MONETARY=el_GR.UTF-8
LC_MESSAGES="en_GB.UTF-8"
LC_PAPER=el_GR.UTF-8
LC_NAME=el_GR.UTF-8
LC_ADDRESS=el_GR.UTF-8
LC_TELEPHONE=el_GR.UTF-8
LC_MEASUREMENT=el_GR.UTF-8
LC_IDENTIFICATION=el_GR.UTF-8
LC_ALL=
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170919/baa1a737/attachment.html>
