[Qgis-user] multiple selection
DelazJ delazj at gmail.com
Thu Sep 21 02:09:45 PDT 2017
Hi Reginald,
The link is available (and functional) from the Plugin Manager. The
repo has been moved to
https://github.com/felferrari/MultipleLayerSelection
HTH,
Harrissou
2017-09-21 8:10 GMT+02:00 Reginald <Reginald.Carlier at ingelmunster.be>:
> Hi,
> I’m writing a script to make a report based on the selection of multiple
> layers.
> The outline of the selection is based on the parcels layer.
> When I use the ‘select by polygon’ tool I can only select the features of
> the selected layer.
> I installed the multiple selection plugin it does what I want, except that I
> need to draw a polygon to include features that are placed on the irregular
> shape of the parcels and that cannot be included by selection by rectangle
> (at least not if you don’t want to select the neigbouring parcels).
> So I would like to adapt the sourcecode of the multiple selection plugin to
> include ‘select by polygon’.
> On the plugin page there is no working link to the code.
> Does anyone know where I can find the code?
> Is there python code for the ‘select by polygon’ maptool?
> Where can I find it?
> Regards,
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
