[Qgis-user] GRASS support lost (again) on Ubuntu/Mint
Andre Joost andre+joost at nurfuerspam.de
Thu Sep 28 05:31:20 PDT 2017
Am 27.09.2017 um 19:21 schrieb Alex M:
> Ah that makes sense, if qgis.org builds against ubuntugis, then GRASS
> updates will always cause this, since a rebuild of qgis.org is not
> triggered.
The same applies to GDAl (and maybe PROJ if the planned improvements
come on the way).
 > Seems like some logistics could be worked out.
As a end-user-friendly solution, it would be great if ubuntugis could
leave a copy of the last build on the server. This could be limited to
the most-critical packages.
This works good in OSGEO4W in case any package causes unwanted corruption.
Greetings,
André Joost
