[Qgis-user] GRASS support lost (again) on Ubuntu/Mint
Angelos Tzotsos gcpp.kalxas at gmail.com
Thu Sep 28 10:04:15 PDT 2017
On 09/28/2017 03:31 PM, Andre Joost wrote:
> Am 27.09.2017 um 19:21 schrieb Alex M:
>> Ah that makes sense, if qgis.org builds against ubuntugis, then GRASS
>> updates will always cause this, since a rebuild of qgis.org is not
>> triggered.
> The same applies to GDAl (and maybe PROJ if the planned improvements
> come on the way).
> > Seems like some logistics could be worked out.
> As a end-user-friendly solution, it would be great if ubuntugis could
> leave a copy of the last build on the server. This could be limited to
> the most-critical packages.
> This works good in OSGEO4W in case any package causes unwanted
> corruption.
> Greetings,
> André Joost
> Qgis-user mailing list
Unfortunately this is not supported by Launchpad.
Only one version is in "published" state.
Cheers,
Angelos
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
