[Qgis-user] Compiling QGIS3 with grass7 from MacPorts
Patrick Dunford
blackwhitekez at gmail.com
Thu Sep 28 17:55:05 PDT 2017
Hi, this is only a generalised comment about building packages and may
not be specific enough for your application.
When I build packages from source they come with Grass so I don't see
how it would not be included in the same scripts for the platform you
are using.
Are there any error logs for building the plugins that will show what is
happening for example the library is not found or wrong version?
On 29/09/17 13:12, David Liontooth wrote:
> I'm interested in reading LIDAR data, which appears to require GRASS
> (I'm new to this).
> I'm trying to compile QGIS2.99 (master) on OS X and short of GRASS
> everything is working -- the program starts up with
> open QGIS
> MacPorts has gdal-grass @2.2.0 (gis), which pulls in grass7. It ends
> up here:
> /opt/local/share/grass-7.2.2/lib
> so for instance /opt/local/share/grass-7.2.2/lib/libgrass_lidar.dylib.
> How do I tell the QGIS build scripts to include grass7?
> Cheers,
> Dave
> Qgis-user mailing list
