[Qgis-user] Compiling QGIS3 with grass7 from MacPorts
Patrick Dunford blackwhitekez at gmail.com
Thu Sep 28 18:53:28 PDT 2017
OK
given the limited support for non-native platforms such as MacOS the
virtualbox option is worth considering. I have drawn hundreds of km of
maps in virtual machines, performance is essentially 99.99% of what is
available on a native application.
On 29/09/17 14:50, David Liontooth wrote:
> INSTALL says this under the OS X section:
>     Also available is a GRASS application:
>     http://www.kyngchaos.com/software/grass
> -- though it turns out that page is for Grass 6; for Grass 7 that page
> in turn points to http://grassmac.wikidot.com. Grass 6 is no longer
> supported in QGIS.
> These options are distinctly less appealing to me than MacPorts --
> first, you have to trust the packagers blindly; secondly, the packages
> don't integrate with other packages. What they're calling "frameworks"
> is dependencies; these installers invite dependency hell.
> QGIS should have general instructions for compiling with organized OS
> X packaging systems.
> MacPorts and HomeBrew do a lot of quality checking, permit easy
> upgrades and uninstallations, and ensure consistent package relations,
> package hash authentication, and community bug reporting. In fact they
> already package QGIS, just not the unrealeased QGIS3.
> Cheers,
> Dave
> On 9/28/17 6:14 PM, Patrick Dunford wrote:
>> Ok, I'm not familirar with a separate build step, don't remember
>> seeing that in the install documentation, unless that is a specific
>> variation for your platform?
>> On 29/09/17 14:12, David Liontooth wrote:
>>> Hi Patrick,
>>> I'm using today's QGIS git master and get this in the configure output:
>>>       -- QGIS version: 2.99.0 Master (29900)
>>>       -- Could not find GRASS 7
>>> The INSTALL file makes it clear it must be built separately, but
>>> suggests using other "Install development frameworks".
>>> The installation procedure for MacOS X with MacPorts is not documented.
>>> Cheers,
>>> Dave
>>> On 9/28/17 5:55 PM, Patrick Dunford wrote:
>>>> Hi, this is only a generalised comment about building packages and
>>>> may not be specific enough for your application.
>>>> When I build packages from source they come with Grass so I don't
>>>> see how it would not be included in the same scripts for the
>>>> platform you are using.
>>>> Are there any error logs for building the plugins that will show
>>>> what is happening for example the library is not found or wrong
>>>> version?
>>>> On 29/09/17 13:12, David Liontooth wrote:
>>>>> I'm interested in reading LIDAR data, which appears to require
>>>>> GRASS (I'm new to this).
>>>>> I'm trying to compile QGIS2.99 (master) on OS X and short of GRASS
>>>>> everything is working -- the program starts up with
>>>>>     open QGIS
>>>>> MacPorts has gdal-grass @2.2.0 (gis), which pulls in grass7. It
>>>>> ends up here:
>>>>>     /opt/local/share/grass-7.2.2/lib
>>>>> so for instance
>>>>> /opt/local/share/grass-7.2.2/lib/libgrass_lidar.dylib.
>>>>> How do I tell the QGIS build scripts to include grass7?
>>>>> Cheers,
>>>>> Dave
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
