[Qgis-user] Compiling QGIS3 with grass7 from MacPorts
David Liontooth
lionteeth at cogweb.net
Thu Sep 28 21:27:22 PDT 2017
The compilations problems on OS X aren't serious, and I'm sure someone
already knows how to overcome them.
Since OS X is unix, it's not really a non-native platform -- it runs the
whole GNU tool chain. A vm is certainly an option, but this doesn't look
hard.
Cheers,
Dave
On 9/28/17 6:53 PM, Patrick Dunford wrote:
> OK
> given the limited support for non-native platforms such as MacOS the
> virtualbox option is worth considering. I have drawn hundreds of km of
> maps in virtual machines, performance is essentially 99.99% of what is
> available on a native application.
> On 29/09/17 14:50, David Liontooth wrote:
>> INSTALL says this under the OS X section:
>> Also available is a GRASS application:
>> http://www.kyngchaos.com/software/grass
>> -- though it turns out that page is for Grass 6; for Grass 7 that
>> page in turn points to http://grassmac.wikidot.com. Grass 6 is no
>> longer supported in QGIS.
>> These options are distinctly less appealing to me than MacPorts --
>> first, you have to trust the packagers blindly; secondly, the
>> packages don't integrate with other packages. What they're calling
>> "frameworks" is dependencies; these installers invite dependency hell.
>> QGIS should have general instructions for compiling with organized OS
>> X packaging systems.
>> MacPorts and HomeBrew do a lot of quality checking, permit easy
>> upgrades and uninstallations, and ensure consistent package
>> relations, package hash authentication, and community bug reporting.
>> In fact they already package QGIS, just not the unrealeased QGIS3.
>> Cheers,
>> Dave
>> On 9/28/17 6:14 PM, Patrick Dunford wrote:
>>> Ok, I'm not familirar with a separate build step, don't remember
>>> seeing that in the install documentation, unless that is a specific
>>> variation for your platform?
>>> On 29/09/17 14:12, David Liontooth wrote:
>>>> Hi Patrick,
>>>> I'm using today's QGIS git master and get this in the configure
>>>> output:
>>>> -- QGIS version: 2.99.0 Master (29900)
>>>> -- Could not find GRASS 7
>>>> The INSTALL file makes it clear it must be built separately, but
>>>> suggests using other "Install development frameworks".
>>>> The installation procedure for MacOS X with MacPorts is not
>>>> documented.
>>>> Cheers,
>>>> Dave
>>>> On 9/28/17 5:55 PM, Patrick Dunford wrote:
>>>>> Hi, this is only a generalised comment about building packages and
>>>>> may not be specific enough for your application.
>>>>> When I build packages from source they come with Grass so I don't
>>>>> see how it would not be included in the same scripts for the
>>>>> platform you are using.
>>>>> Are there any error logs for building the plugins that will show
>>>>> what is happening for example the library is not found or wrong
>>>>> version?
>>>>> On 29/09/17 13:12, David Liontooth wrote:
>>>>>> I'm interested in reading LIDAR data, which appears to require
>>>>>> GRASS (I'm new to this).
>>>>>> I'm trying to compile QGIS2.99 (master) on OS X and short of
>>>>>> GRASS everything is working -- the program starts up with
>>>>>> open QGIS
>>>>>> MacPorts has gdal-grass @2.2.0 (gis), which pulls in grass7. It
>>>>>> ends up here:
>>>>>> /opt/local/share/grass-7.2.2/lib
>>>>>> so for instance
>>>>>> /opt/local/share/grass-7.2.2/lib/libgrass_lidar.dylib.
>>>>>> How do I tell the QGIS build scripts to include grass7?
>>>>>> Cheers,
>>>>>> Dave
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
