[Qgis-user] Compiling QGIS3 with grass7 from MacPorts
Patrick Dunford
blackwhitekez at gmail.com
Thu Sep 28 21:44:47 PDT 2017
Sorry I misread the documentation, it looked like the mac port was a
third party one.
On 29/09/17 17:27, David Liontooth wrote:
> The compilations problems on OS X aren't serious, and I'm sure someone
> already knows how to overcome them.
> Since OS X is unix, it's not really a non-native platform -- it runs
> the whole GNU tool chain. A vm is certainly an option, but this
> doesn't look hard.
> Cheers,
> Dave
> On 9/28/17 6:53 PM, Patrick Dunford wrote:
>> OK
>> given the limited support for non-native platforms such as MacOS the
>> virtualbox option is worth considering. I have drawn hundreds of km
>> of maps in virtual machines, performance is essentially 99.99% of
>> what is available on a native application.
>> On 29/09/17 14:50, David Liontooth wrote:
>>> INSTALL says this under the OS X section:
>>> Also available is a GRASS application:
>>> http://www.kyngchaos.com/software/grass
>>> -- though it turns out that page is for Grass 6; for Grass 7 that
>>> page in turn points to http://grassmac.wikidot.com. Grass 6 is no
>>> longer supported in QGIS.
>>> These options are distinctly less appealing to me than MacPorts --
>>> first, you have to trust the packagers blindly; secondly, the
>>> packages don't integrate with other packages. What they're calling
>>> "frameworks" is dependencies; these installers invite dependency hell.
>>> QGIS should have general instructions for compiling with organized
>>> OS X packaging systems.
>>> MacPorts and HomeBrew do a lot of quality checking, permit easy
>>> upgrades and uninstallations, and ensure consistent package
>>> relations, package hash authentication, and community bug reporting.
>>> In fact they already package QGIS, just not the unrealeased QGIS3.
>>> Cheers,
>>> Dave
>>> On 9/28/17 6:14 PM, Patrick Dunford wrote:
>>>> Ok, I'm not familirar with a separate build step, don't remember
>>>> seeing that in the install documentation, unless that is a specific
>>>> variation for your platform?
>>>> On 29/09/17 14:12, David Liontooth wrote:
>>>>> Hi Patrick,
>>>>> I'm using today's QGIS git master and get this in the configure
>>>>> output:
>>>>> -- QGIS version: 2.99.0 Master (29900)
>>>>> -- Could not find GRASS 7
>>>>> The INSTALL file makes it clear it must be built separately, but
>>>>> suggests using other "Install development frameworks".
>>>>> The installation procedure for MacOS X with MacPorts is not
>>>>> documented.
>>>>> Cheers,
>>>>> Dave
>>>>> On 9/28/17 5:55 PM, Patrick Dunford wrote:
>>>>>> Hi, this is only a generalised comment about building packages
>>>>>> and may not be specific enough for your application.
>>>>>> When I build packages from source they come with Grass so I don't
>>>>>> see how it would not be included in the same scripts for the
>>>>>> platform you are using.
>>>>>> Are there any error logs for building the plugins that will show
>>>>>> what is happening for example the library is not found or wrong
>>>>>> version?
>>>>>> On 29/09/17 13:12, David Liontooth wrote:
>>>>>>> I'm interested in reading LIDAR data, which appears to require
>>>>>>> GRASS (I'm new to this).
>>>>>>> I'm trying to compile QGIS2.99 (master) on OS X and short of
>>>>>>> GRASS everything is working -- the program starts up with
>>>>>>> open QGIS
>>>>>>> MacPorts has gdal-grass @2.2.0 (gis), which pulls in grass7. It
>>>>>>> ends up here:
>>>>>>> /opt/local/share/grass-7.2.2/lib
>>>>>>> so for instance
>>>>>>> /opt/local/share/grass-7.2.2/lib/libgrass_lidar.dylib.
>>>>>>> How do I tell the QGIS build scripts to include grass7?
>>>>>>> Cheers,
>>>>>>> Dave
>>>>>>> _______________________________________________
>>>>>>> Qgis-user mailing list
>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
