[Qgis-user] Bug or Feature - QGIS 3.2 raster styling
Nyall Dawson
nyall.dawson at gmail.com
Wed Aug 1 15:05:53 PDT 2018
On Wed, 1 Aug 2018 at 11:13, Shawn Carter <shawn.m.carter at gmail.com> wrote:
> Sure. https://1drv.ms/f/s!AhIPPYddAyx1gdsPGUUrwQMwtCGqOA
> In that web share folder you'll find a GeoTiff with values ranging from -1 to 1. The second file is a style file with three classes. If you remove the middle class, my QGIS will quit displaying any values...add a third class it works.
Thanks - fixed.
Nyall
> On Tue, Jul 31, 2018 at 4:31 PM Nyall Dawson <nyall.dawson at gmail.com> wrote:
>> On Wed, 1 Aug 2018 at 02:21, Shawn Carter <shawn.m.carter at gmail.com> wrote:
>> > One of the more common tasks I use QGIS for is creating flood inundation and water extent maps using a variety of remotely sensed data. My general method for visualizing the data was to create a discrete singlelayer pseudocolor ramp with two classes. For example, if using NDWI data I would set values of [-1, 0.1] as fully transparent and [0.1, 1] as opaque shade of blue. On Ubuntu 18.04, QGIS 3.2 I've noticed that if I only use two classes, the data isn't displayed. If I add a third class it will be displayed. Is this a problem and should I submit a bug report?
>> Could you share a sample dataset and project showing this issue?
>> Nyall
