[Qgis-user] QGIS 2.18 - Layereigenschaften - Felder - Kommentar
Andreas Neumann
a.neumann at carto.net
Thu Aug 2 01:33:20 PDT 2018
Hi Ingrid,
Are you aware that this e-mail list is for "english language"? If you
want to discuss in german language, please use the fossgis-talk email
list. See https://lists.fossgis.de/mailman/listinfo/fossgis-talk-liste
Regarding your question:
It has been under discussion whether the "Comments" should be displayed
as tooltips over the widgets, however, this should be an opt-in (not on
by default), because it can also be annoying. And it isn't implemented
yet.
The comments are originally to see comments from database fields (e.g.
Postgis) - and such comments can be rather technical, rather than being
meant for the average users - however, I could see value, as an opt in -
to display such comments as tooltips.
For your other issues:
If you have the choice, I would recomment that you set up your projects
with QGIS 3.x rather than QGIS 2.18 - because with 3.x there is more
control on data restrictions and default values (on insert and update).
As Günter mentioned, you can also use "Aliases" to display hints for
user input by users. And in QGIS 3.x. you can add units into widgets,
e.g. to indicate what unit an input value is meant for.
Hope this helps and greetings,
Andreas
On 2018-08-01 19:13, ing rid wrote:
> Hallo liebe QGISler,
> weil ich online nicht weiterkomme möchte ich diese Frage an euch
> weitergeben:
> Ich habe eine Shapefile (Vektor, Punkte) mit umfangreicher Attributtabelle
> erstellt, in die verschiedene Menschen unabhängig voneinander ihre Daten
> eintragen sollen.
> Damit die Daten in allen Feldern später kompatibel sind möchte ich die
> Felder gerne kommentieren (welche Information soll hier eingegeben werden
> und in welcher Form, z.B. welches Datumformat ins Feld 'Datum').
> Wenn ich neue Felder anlege kann ich dazu einen Kommentar eingeben - das
> klingt für mich wie dafür gemacht!! - Allerdings finde ich die dort
> eingetragenen Informationen nirgendwo wieder!
> In den Layereigenschaften unter Felder wird eine Spalte 'Kommentar'
> angezeigt - hier hätte ich die von mir hinterlegten Kommentare eigentlich
> erwartet... nur sind die Felder alle leer!, obwohl ich neue 'kommentierte'
> Felder angelegt habe (mit und ohne Feldrechner...). Die Kommentarspalte kann
> ich hier auch bearbeiten und neuen Text eingeben, aber wenn ich die
> Layereigenschaften wieder schließe und erneut öffne ist davon nichts mehr zu
> sehen.
> Ich habe die Kommentar-Funktion mit und ohne Bearbeitungsmodus ausprobiert,
> aber ohne Erfolg: egal wie ich versuche, einen Kommentar zu einer Spalte zu
> erstellen, es will mir nicht gelingen.
> Nach wie vor fände ich eine solche Funktion aber sehr praktisch - also
> vielleicht kennt ja jemand die Lösung? oder einen entsprechenden
> Alternativ-Vorschlag um beschreibenden Text zu einer Spalte hinzuzufügen?
> zur den technischen Rahmenbedingungen:
> ich benutze QGIS Desktop 2.18 auf Windows 10 Pro.
> Vielen Lieben Dank und hoffnungsvolle Grüße,
> Ingrid
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180802/b314b001/attachment.html>
