[Qgis-user] QGIS 3.2.0 Layer Style issue
Richard McDonnell
richard.mcdonnell at opw.ie
Thu Aug 2 01:41:43 PDT 2018
Andreas,
Thanks for getting back. I need the Symbols and Labels for zoom levels 1:2,000,000 and 1:20,001, so the No Symbols, won’t do the trick for me unfortunately.
I assumed that with separate rendering (Scale Ranges) that I would be able to make the switch from Symbols and Labels to Labels Only, seamlessly with a single Layer.
Maybe this is something which could be implemented in future versions?
I may have to just use duplicate layering, to achieve the result I want, Thanks again for getting back.
Regards,
Richard.
From: Andreas Neumann [mailto:a.neumann at carto.net]
Sent: 02 August 2018 09:26
To: Richard McDonnell <richard.mcdonnell at opw.ie>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS 3.2.0 Layer Style issue
Hi Richard,
Have you tried setting the "No symbols" renderer in the symbology? Such features should still be available for labels, but aren't drawn.
Andreas
On 2018-08-01 15:58, Richard McDonnell wrote:
Afternoon all,
I have ran into a little issue in styling on QGIS 3.2.1.
I have a line style ceated for a road network, what I want it to do is display the Lines and Labels between, say, 1:2,000,000 and 1:20,001 and from 1:20000 to 1:500 just the Labels.
I have used Rule based styling to create a style, with separate overlapping Scale Ranges, which works perfectly for 1:2,000,000 to 1:20,001, but once the Lines (Symbology) disappear, so do the Labels.
If I reset the Scale range on the Symbology (Have no restrictions, the Labels work as required, all the way to 1:500.
It seems that even though I have separate scale ranges set for both the symbology and the labels, once the symbols switch off so does the labels.
Is there a way for me to do what I want without having to duplicating the network layer, so as I have a separate Symbols layer and Label Layer.
Any help appreciated.
Regards,
Richard.
[Image removed by sender.]<http://www.opw.ie/>
Email Disclaimer: http://www.opw.ie/en/disclaimer/
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180802/9d1d4e2e/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180802/9d1d4e2e/attachment.jpg>
