[Qgis-user] Install ver. 2.14 and 3.2 on the same computer
Maria Shinoto maria at shinoto.de
Thu Aug 2 16:09:54 PDT 2018
Hi Esther,
Thanks a lot. So I will give it a try and return to this list, if there are problems I cannot locate.
As for projects, yes, it seems that version 3 stores them differently, but this is no problem in my case.
Best,
Maria
> Am 2018-08-02 um 20:36 schrieb Gomes, Esther <egomes at cbcl.ca>:
> Hi Maria,
> I keep both 3.2 and 2.18 on my computer, and they each work fine. From looking at them, QGIS 2.18 uses GRASS 7.4.0, while QGIS 3.2 uses GRASS 7.4.1.
> I will caution that I've opened qgs files saved from 3.2 in 2.18 and some of the stylings or properties aren't there. Particularly the print composer is a bit different, and QGIS 2.18 couldn't see any of my layouts I had created.
> Esther
> -----Original Message-----
> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Maria Shinoto
> Sent: August-02-18 08:14
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Install ver. 2.14 and 3.2 on the same computer
> Hi,
> I am new to QGIS and installed version 3.2 in the beginning, with GDAL, GRASS 7, etc. in their newest incarnations.
> Now I cooperate with people who use the Japanese version 2.14 on Windows (I am on a Mac), and together with older versions of GDAL and GRASS 7 (I suppose) and mathplotlib.
> On the other hand, I have already started working with version 3.2, which works nice for my project.
> So I would like to keep both versions on my Mac.
> I cannot find any information about the parallel use of GRASS, GDAL in different versions, or whether I can use the newest versions with 2.14 as well. And I cannot find informations whether I harm version 3.2 when I install mathplotlib.
> Since there are additional problems with Japanese encodings etc., I would like to reduce the potential of trouble in the first place, there is a lot that seems to go wrong.
> Python 2.x and 3.x is of course not problem.
> Thanks for any hint reg.
> - GDAL
> - GRASS
> - mathplotlib
> Maria
> Qgis-user mailing list
