[Qgis-user] Importing Cropland Data Layer
Alex M
tech_dev at wildintellect.com
Fri Aug 3 13:44:14 PDT 2018
Interesting, that also works fine for me. Out of curiosity what order
did you add the layers in?
A workaround that might be more reliable would be to install the
Quick_Map_Services plugin (Check it's settings and add the Contributed
Pack). You'll be able to add the same layer from ESRI via that plugin
and it's usually pretty good about checking the projection issues.
Thanks,
Alex
On 08/03/2018 01:37 PM, Emily Wine wrote:
> Alex,
> I added World Imagery by pasting this code into the Python Console:
> *qgis.utils.iface.addRasterLayer("http://server.arcgisonline.com/arcgis/rest/services/ESRI_Imagery_World_2D/MapServer?f=json&pretty=true","raster"
> <http://server.arcgisonline.com/arcgis/rest/services/ESRI_Imagery_World_2D/MapServer?f=json&pretty=true%22,%22raster%22>)*
> Thanks so much,
> Emily
> On Fri, Aug 3, 2018 at 1:33 PM, Alex M <tech_dev at wildintellect.com> wrote:
>> Ah, it changed in QGIS 3. How did you add the World Imagery?
>> Your CDL file and one I downloaded worked fine for me in QGIS 2 and QGIS 3.
>> Thanks,
>> Alex
>> On 08/03/2018 01:16 PM, Emily Wine wrote:
>>> Alex,
>>> I don't see any option to enable on the fly transformation. I've
>> attached a
>>> link showing what I see on my screen.
>>> Thanks,
>>> Emily
>>> On Fri, Aug 3, 2018 at 1:03 PM, Alex M <tech_dev at wildintellect.com>
>> wrote:
>>>> On 08/03/2018 12:50 PM, Alex M wrote:
>>>>> On 08/03/2018 11:52 AM, Emily Wine wrote:
>>>>>> Hi everyone!
>>>>>> I am completely new to QGIS (and mapping in general), and I can't get
>> my
>>>>>> layers to line up.
>>>>>> * QGIS Version: 3.2.1-BonnStandalone-installerWindows 10 64-bit*
>>>>>> *All of my layers are in the USA Contiguous Albers Equal Area
>>>> projection.*
>>>>>> Currently, I have three layers:
>>>>>> Site Coordinates
>>>>>> World Imagery layer from ESRI
>>>>>> Cropland Data Layer (CDL) from USDA-NASS CropScape
>>>>>> My coordinates line up perfectly with the World Imagery layer.
>> However,
>>>> the
>>>>>> CDL is floating somewhere out in the universe and won't line up.
>>>>>> CDL Extent:
>>>>>> 48885.0000000000000000,2818725.0000000000000000 :
>>>>>> 117585.0000000000000000,2930685.0000000000000000
>>>>>> I downloaded the CDL as a zipped file containing a .tif and a
>>>> .vat.dbf.tif
>>>>>> file.
>>>>>> I unzipped the file and uploaded it to QGIS as a .tif file.
>>>>> Can you please provide a link to what you downloaded.
>>>>>> Is it possible that the georeferencing for the .tif file is encoded in
>>>> the
>>>>>> .vat.dbf.tif file? How do I import the Cropland Data Layer to QGIS?
>>>>> Nope, thats a value attribute database file.
>>>>>> Thanks,
>>>>>> Emily
>>>>> It's very likely that QGIS is just reading the projection data
>>>>> incorrectly. Check the Properties/Metadata tab for the layer to see
>> what
>>>>> projection QGIS assigned the layer.
>>>>> Was there a tfw with the data? that would contain georeference.
>>>>> Thanks,
>>>>> Alex
>>>> PS: Do you have projection on the Fly (OTF) enabled?
>>>> https://docs.qgis.org/testing/en/docs/user_manual/working_
>>>> with_projections/working_with_projections.html#define-on-
>>>> the-fly-otf-crs-transformation
>>>> -Alex
