[Qgis-user] Keep both qgis2.18 and qgis3.0.2 on Debian machine?
Alexandre Neto
senhor.neto at gmail.com
Mon Aug 6 04:31:42 PDT 2018
all methods to have more than one qgis version on Linux (debian) have
already been mentioned.
I normally install QGIS 3 stable using the normal repositories, I compile
QGIS 3 master from source, and I install QGIS 2.18 using conda-forge.
To compile QGIS you need to follow the instructions available on the source:
https://github.com/qgis/QGIS/blob/master/INSTALL
Don't forget the change the branch in case you want to install qgis 2.18 or
qgis 3
To install QGIS 2.18 using conda follow the instructions in here:
https://www.northrivergeographic.com/archives/running-2-version-of-qgis-on-ubuntu-linux
Hope it helps,
Alex
Luke Pinner <lukepinnerau at gmail.com> escreveu no dia segunda, 6/08/2018 às
11:11:
> I don't know the details of debian packaging, but a separate deb package
> would have made the transition easier. They can certainly coexist with some
> separation of the environments.
> What I do is install 3x via apt from the qgis.org repo and 2.18 in a
> conda env from the conda-forge channel.
> Luke
> On Mon., 6 Aug. 2018, 20:00 Agustin Lobo, <alobolistas at gmail.com> wrote:
>> Thanks,
>> Would not have been better releasing qgis3 as if it were a different
>> package?
>> As an alternative to the virtual machine, is not possible to keep
>> qgis2.18 and qgsi3 if
>> I compile qgis3 myself? If this is possible, any directions on how to do
>> it?
>> Thanks
>> On Mon, Aug 6, 2018 at 9:57 AM, Andre Joost <andre+joost at nurfuerspam.de>
>> wrote:
>> > Am 06.08.18 um 09:05 schrieb Agustin Lobo:
>> >> Is it possible (and advised) to keep coexisting both qgis2.18 and
>> >> qgis3 on the same Debian testing machine?
>> >> How? I understand that if I just use Synaptic
>> >> to upgrade, qgis2.18 will be removed.
>> > You can only have both if you put one in a virtual machine. With shared
>> > folders you can still use the same data files.
>> > HTH,
>> > Andre Joost
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180806/1a934889/attachment.html>
