[Qgis-user] Keep both qgis2.18 and qgis3.0.2 on Debian machine?
Luke Pinner
lukepinnerau at gmail.com
Mon Aug 6 03:11:01 PDT 2018
I don't know the details of debian packaging, but a separate deb package
would have made the transition easier. They can certainly coexist with some
separation of the environments.
What I do is install 3x via apt from the qgis.org repo and 2.18 in a conda
env from the conda-forge channel.
Luke
On Mon., 6 Aug. 2018, 20:00 Agustin Lobo, <alobolistas at gmail.com> wrote:
> Thanks,
> Would not have been better releasing qgis3 as if it were a different
> package?
> As an alternative to the virtual machine, is not possible to keep
> qgis2.18 and qgsi3 if
> I compile qgis3 myself? If this is possible, any directions on how to do
> it?
> Thanks
> On Mon, Aug 6, 2018 at 9:57 AM, Andre Joost <andre+joost at nurfuerspam.de>
> wrote:
> > Am 06.08.18 um 09:05 schrieb Agustin Lobo:
> >> Is it possible (and advised) to keep coexisting both qgis2.18 and
> >> qgis3 on the same Debian testing machine?
> >> How? I understand that if I just use Synaptic
> >> to upgrade, qgis2.18 will be removed.
> > You can only have both if you put one in a virtual machine. With shared
> > folders you can still use the same data files.
> > HTH,
> > Andre Joost
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180806/6b9c7c1a/attachment.html>
