[Qgis-user] Keep both qgis2.18 and qgis3.0.2 on Debian machine?
Agustin Lobo
alobolistas at gmail.com
Mon Aug 6 02:59:55 PDT 2018
Thanks,
Would not have been better releasing qgis3 as if it were a different package?
As an alternative to the virtual machine, is not possible to keep
qgis2.18 and qgsi3 if
I compile qgis3 myself? If this is possible, any directions on how to do it?
Thanks
On Mon, Aug 6, 2018 at 9:57 AM, Andre Joost <andre+joost at nurfuerspam.de> wrote:
> Am 06.08.18 um 09:05 schrieb Agustin Lobo:
>> Is it possible (and advised) to keep coexisting both qgis2.18 and
>> qgis3 on the same Debian testing machine?
>> How? I understand that if I just use Synaptic
>> to upgrade, qgis2.18 will be removed.
> You can only have both if you put one in a virtual machine. With shared
> folders you can still use the same data files.
> HTH,
> Andre Joost
> Qgis-user mailing list
