[Qgis-user] QGIS 3 Standalone Python Script
Santiago Higuera shiguera at mercatorlab.com
Mon Aug 6 04:32:21 PDT 2018
In my linux system I need /usr/lib/python3/dist-packages, taking the
python from QGIS (QGIS install its own python, it don't use the python
installed in the system)
El 06/08/18 a las 03:04, Chris B escribió:
> Thanks for the tip - nothing odd stands out...
> ['/Applications/QGIS3.app/Contents/Resources/python/plugins',
>   '/Applications/QGIS3.app/Contents/Resources/python/',
>   '/Users/cbarnes/scripts',
>   '/Applications/QGIS3.app/Contents/Resources/python',
>   '/Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip',
>   '/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6',
> '/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload',
>   '/Users/cbarnes/Library/Python/3.6/lib/python/site-packages',
> '/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages']
> Is there one that is obvious is missing?
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
