[Qgis-user] QGIS 3 Standalone Python Script
DT
dmofot at gmail.com
Mon Aug 6 11:47:17 PDT 2018
Thanks William! All is working now.
Chris - here's what is working for me:
https://gist.github.com/dmofot/94345126db10660053ccfb0d76a1e32a
and I'm just passing the layers (full path) into the script. For example,
/Users/<user>/Documents/<shp_filename.shp>
DT
On Mon, Aug 6, 2018 at 11:03 AM, Chris B <snowstorms at mac.com> wrote:
> Thanks so much for helping out with this.
> The script now no longer fails looking for Qt, great!
> But I'm still getting a very basic error -- loading a layer from the file
> system doesn't work. Here's the script:
> import sys
> sys.path.insert(0,'/Applications/QGIS3.app/Contents/Frameworks/')
> sys.path.insert(0,'/Applications/QGIS3.app/Contents/Resources/python/')
> plugins')
> from qgis.core import (
> QgsApplication,
> QgsProcessingFeedback,
> QgsVectorLayer
> from qgis.analysis import QgsNativeAlgorithms
> # Start the QGIS App
> qgs = QgsApplication([], False)
> qgs.initQgis()
> # Start Processing plugin
> import processing
> from processing.core.Processing import Processing
> Processing.initialize()
> QgsApplication.processingRegistry().addProvider(QgsNativeAlgorithms())
> # Load Layer
> layer = QgsVectorLayer('21185.shp', 'my layer', 'ogr')
> if not layer.isValid():
> print("Layer failed to load!")
> # Set parameters
> params = {
> 'INPUT': layer,
> 'OUTPUT': 'memory:'
> feedback = QgsProcessingFeedback()
> # Run processing algorithm
> res = processing.run("native:extractvertices", params, feedback=feedback)
> res['OUTPUT'] # Access your output layer
> When I test for layer validity, it says the layer fails to load and then
> segfaults (which makes sense since the object is null).
> I tried referring to the file locally (eg. 'file.shp') and from the root of
> the drive ('/Users/[user]/path/to/script/file.shp') and neither worked.
> Am I missing something for QgsVectorLayer to work? Seems like an odd
> error.
> Thanks again,
> C.
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180806/a560ce67/attachment.html>
