[Qgis-user] QGIS 3 Standalone Python Script
Chris B
snowstorms at mac.com
Mon Aug 6 08:03:29 PDT 2018
Thanks so much for helping out with this.
The script now no longer fails looking for Qt, great!
But I'm still getting a very basic error -- loading a layer from the file
system doesn't work. Here's the script:
import sys
sys.path.insert(0,'/Applications/QGIS3.app/Contents/Frameworks/')
sys.path.insert(0,'/Applications/QGIS3.app/Contents/Resources/python/')
sys.path.insert(0,'/Applications/QGIS3.app/Contents/Resources/python/plugins')
from qgis.core import (
QgsApplication,
QgsProcessingFeedback,
QgsVectorLayer
from qgis.analysis import QgsNativeAlgorithms
# Start the QGIS App
qgs = QgsApplication([], False)
qgs.initQgis()
# Start Processing plugin
import processing
from processing.core.Processing import Processing
Processing.initialize()
QgsApplication.processingRegistry().addProvider(QgsNativeAlgorithms())
# Load Layer
layer = QgsVectorLayer('21185.shp', 'my layer', 'ogr')
if not layer.isValid():
print("Layer failed to load!")
# Set parameters
params = {
'INPUT': layer,
'OUTPUT': 'memory:'
feedback = QgsProcessingFeedback()
# Run processing algorithm
res = processing.run("native:extractvertices", params, feedback=feedback)
res['OUTPUT'] # Access your output layer
When I test for layer validity, it says the layer fails to load and then
segfaults (which makes sense since the object is null).
I tried referring to the file locally (eg. 'file.shp') and from the root of
the drive ('/Users/[user]/path/to/script/file.shp') and neither worked.
Am I missing something for QgsVectorLayer to work? Seems like an odd error.
Thanks again,
C.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
