[Qgis-user] import raw binary raster data
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Tue Aug 7 19:10:28 PDT 2018
r.in.bin is not available in the processing. Is there an EASY way to
import into QGIS a raw binary raster data set? According to
https://lists.osgeo.org/pipermail/qgis-user/2010-October/010157.html,
there was such a plugin in the past. If there is not an easy way, I
guess creating a VRT file and using GDAL will be the only way out.
https://www.gdal.org/gdal_vrttut.html#gdal_vrttut_overviews
If I need to use a VRT file, what would be the <ByteOrder> value for a
big endian byte order? LSB or MSB? (or am I getting the byte order
thing wrong???) I am on Windows 10.
Thanks
Nicolas
