[Qgis-user] Popup content aligned to the right
    Philip Barlow
    philipb at pembrokeshirecoast.org.uk
    Wed Aug  8 02:00:41 PDT 2018
Hi Yossi,
Z-index works in leaflet, example attached.
Failing that you could try div’ing out the whole map and adding titles and attributions above and below in html?
Phil
From: Yossi Rokni [mailto:yossi.rokni at gmail.com]
Sent: 07 August 2018 15:15
To: Philip Barlow
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Popup content aligned to the right
Thanks Phil,
This solves the problem when I use Leaflet (it didn't work for me when I used OpenLayers).
Actually I used this:
.leaflet-popup-content {
    width:margin-right !important;
    padding-right:5px;
text-align: Right;
But this solution causes 2 problems.
•         Every time I will export again the map, it will create a new CSS file, without this manual update.
Is there a way to make this update permanent (like using a template)?
•         When I worked with OpenLeayers (and not with Leaflet), I had the authors' name displayed on the map using the following in the template (thanks to your help):
        </div>
              <div style="position: fixed; bottom:0;left:0; background-color: white; opacity:0.6; padding:0px;z-index:2;">
              <h1>authors' name</h1>
             </div>
But now that I work with Leaflet, the authors' name is not seen on the map. It seems like it appears for a fraction of a second and then it disappears under the map.
I tried playing with the z-index values: 1, 2, 3, with no success.
Do you know what needs to be done in Leaflet in order to show it on the map?
It worked fine in OpenLayers.
Yossi
בתאריך יום ב׳, 6 באוג׳ 2018 ב-10:12 מאת Philip Barlow <philipb at pembrokeshirecoast.org.uk<mailto:philipb at pembrokeshirecoast.org.uk>>:
Hi Yossi,
There isn’t an option to do this in the plugin but its easily done in the style sheet. Open up qgis2web.css in the css folder of the plugin output.
Add “text-align:” to leaflet pop-up content.
e.g.
                 width:200px;
                 padding-right:10px;
text-align: Right;
Phil
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] On Behalf Of Yossi Rokni
Sent: 05 August 2018 14:18
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Popup content aligned to the right
I created a web map with a point layer.
The content of the layers' attributes is in Hebrew.
The content is displayed in the popup.
It is aligned to left.
Is there an option to display the popup content aligned to the right? How?
I use QGIS version 2.18.20
I created the web map using qgis2web plugin with OpenLayers
Thanks
Yossi
Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
The Authority is happy to communicate in Welsh or English
Website www.pembrokeshirecoast.org.uk<http://www.pembrokeshirecoast.org.uk>
Follow us on Twitter<http://twitter.com/PembsCoast>
Join us on Facebook<http://www.facebook.com/group.php?gid=26330984774&ref=ts>
Watch us on Youtube <http://www.youtube.com/user/pcnpa2008#p/u/0/Tw8Udou0p5k>
Look at us on Flickr<http://www.flickr.com/photos/pembrokeshirecoast/>
This email and any attached files should only be read by those persons to whom
they are addressed and be used by them only for their intended purpose.
If you are not the intended recipient please destroy all copies and inform the
sender by return email.
Please note that the contents of this email may be subject to public disclosure
under the Freedom of Information Act 2000 and therefore the confidentiality of
this message and any reply cannot be guaranteed.
Click here<http://www.pembrokeshirecoast.wales/default.asp?PID=413> to view PCNPA Privacy Notice – Keeping your Information Safe
For further information on the PCNPA please visit our website at www.pembrokeshirecoast.org.uk<http://www.pembrokeshirecoast.org.uk>
Please consider the environment before printing this email.
Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac unrhyw ffeiliau sydd
ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio at y diben y bwriadwyd hwy.
Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech gystal â dinistrio pob copi a rhoi
gwybod i'r anfonwr gyda throad yr e-bost.
Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod cael ei ddatgelu i'r cyhoedd o
dan Deddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu cyfrinachedd y neges hon
nac unrhyw ateb.
Cliciwch yma<http://www.pembrokeshirecoast.wales/default.asp?pid=413&LangID=2> i weld Hysbysiad Preifatrwydd APCAP - Cadw eich Gwybodaeth yn Ddiogel
Am ragor o wybodaeth am APCAP ymwelwch â'n gwefan ar www.arfordirpenfro.org.uk<http://www.arfordirpenfro.org.uk>
Ystyrier yr amgylchedd cyn argraffu'r e-bost hwn os gwelwch yn dda.
בברכה
  יוסי רוקני
Join us on Facebook
Watch us on Youtube
Click here to view PCNPA Privacy Notice  Keeping your Information Safe
nac unrhyw ateb.
Cliciwch yma i weld Hysbysiad Preifatrwydd APCAP - Cadw eich Gwybodaeth yn Ddiogel
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180808/6dadac57/attachment.html>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180808/6dadac57/attachment-0001.html>
