[Qgis-user] Textual representation of styles ?
Ville Koivisto ville.koivisto at kuntotekniikka.fi
Wed Aug 8 02:44:07 PDT 2018
Hi all,
Appreciate your advice. If there are any more resources concerning this, please let me know. Exporting SLD file in QGIS seems to result in SLD 1.0 file, without an option to influence the version.
Simple SLD tests seem to prove Andrea right. I’ve tried to implement a SLD style that has unique symbols for over 10,000 features. Apparently it is validated by Geoserver, but previewing the style on a file, I get nothing. I guess this kind of styling is simply too heavy or otherwise error prone?
Cheers,
Ville Koivisto
+35840 701 4283
GIS Expert
Suomen kuntotekniikka Oy
From: Andrea Aime <andrea.aime at geo-solutions.it>
Sent: Wednesday, August 8, 2018 11:23 AM
To: Richard McDonnell <richard.mcdonnell at opw.ie>
Cc: ville.koivisto at kuntotekniikka.fi; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Textual representation of styles ?
This approach is "old news", if you're using newer versions of QGIS (3+) and GeoServer (hum... 2.13 works, not sure from when, probably 2.11)
then trying to switch it from SLD 1.1 down to SLD 1.0 should be unnecessary, GeoServer should read the exported styling directly.
There are still however various limitations, GeoSolutions launched a crowdfunding initiative some time ago that so far only gathered funds for
label exports (available in QGIS 3.0), but failed to get funds for the rest:
https://www.geo-solutions.it/news/crowdfunding-qgis-geoserver-styling-interoperability/
Cheers
Andrea
On Wed, Aug 8, 2018 at 10:14 AM Richard McDonnell <richard.mcdonnell at opw.ie <mailto:richard.mcdonnell at opw.ie> > wrote:
You can implement it in Geoserver, it just takes a little editing.
Generally what works for me is using something like Notepad++ to:-
1.      Remove all Instances of <se:Description>…</se:Description>
2.      Change all Instances <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"> to <ogc:Filter>
3.      Removing all instances of se:
4.      Change all instances of SvgParameter to CssParameter
This usually sorts any issues out, you will of course need to validate it in GeoServer.
Hope this helps!
Regards,
Richard.
Richard McDonnell
GIS Specialist | FRM Data Management
  _____
Email:   <mailto:richard.mcdonnell at opw.ie> richard.mcdonnell at opw.ie
Phone:  + 353 (0) 1 647 6543
Mobile:  +353 (0) 87 688 5964
The Office of Public Works
52 St. Stephen's Green
Dublin 2 ~ D02 DR67
 <https://facebook.com/opwireland>
 <https://twitter.com/opwireland>
 <https://youtube.com/c/OpwIe>
From: Ville Koivisto [mailto:ville.koivisto at kuntotekniikka.fi <mailto:ville.koivisto at kuntotekniikka.fi> ]
Sent: 08 August 2018 06:28
To: Richard McDonnell <richard.mcdonnell at opw.ie <mailto:richard.mcdonnell at opw.ie> >; 'Lars I. Nielsen, LIFA A/S' <lin at LIFA.DK <mailto:lin at LIFA.DK> >; qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
Subject: RE: [Qgis-user] Textual representation of styles ?
Good morning,
Wait, so I can’t straight away use an SLD file generated in QGIS for styling my layers in Geoserver? Is there any more info about his somewhere?
Thanking you in advance,
Ville Koivisto
+35840 701 4283
GIS Expert
From: Qgis-user <qgis-user-bounces at lists.osgeo.org <mailto:qgis-user-bounces at lists.osgeo.org> > On Behalf Of Richard McDonnell
Sent: Tuesday, August 7, 2018 5:24 PM
To: Lars I. Nielsen, LIFA A/S <lin at LIFA.DK <mailto:lin at LIFA.DK> >; 'qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org> ' <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org> >
Hi Lars,
Would SLD be what you ar looking for?
http://www.opengeospatial.org/standards/sld
QGIS can save its styles to this format, be aware, its not a full implementation of SLD, so it takes a little tweaking to make it work with other SLD compliant software line GeoServer.
Hope it helps,
Richard.
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Lars I. Nielsen, LIFA A/S
Sent: 07 August 2018 14:50
To: 'qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org> ' <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org> >
Subject: [Qgis-user] Textual representation of styles ?
Hi list.
Does QGIS utilize and support textual styles, e.g. as read from data ?
OGR has a feature style specification (https://www.gdal.org/ogr_feature_style.html ), with some examples shown below.
Has anyone used QGIS to facilitate such style representation ?
Here are some example style definition strings:
*	A 5 pixels wide red line:
PEN(c:#FF0000,w:5px)
*	A polygon filled in blue, with a black outline:
BRUSH(fc:#0000FF);PEN(c:#000000)
*	A point symbol:
SYMBOL(c:#00FF00,id:"points.sym-45,ogr-sym-7")
*	A text label, taking the text string from the "text_attribute" attribute field:
LABEL(f:"Times New Roman",s:12pt,t:{text_attribute})"
Here is what a style table that contains all the above styles could look like:
    road:      PEN(c:#FF0000,w:5px)
    lake:      BRUSH(fc:#0000FF);PEN(c:#000000)
    campsite:  SYMBOL(c:#00FF00,id:"points.sym-45,ogr-sym-7")
    label:     LABEL(f:"Times New Roman",s:12pt,t:{text_attribute})
I know that QGIS supports its own XML style format, and supports some form of SLD. Both are layer based, though, not feature based.
Med venlig hilsen
GIS konsulent, FME Certified Professional
T
6313 6800
lin at lifa.dk <mailto:lin at lifa.dk>
D
6313 6849
W
www.lifa.dk <http://www.lifa.dk>
M
2492 4866
Vi tilbyder interne og eksterne kurser. Du kan finde mere information i vores kursuskalender <https://www.lifa.dk/kursuskalender>
 <https://www.linkedin.com/company/lifa-a-s/>
Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S Landinspektører
 <http://www.opw.ie/>
Email Disclaimer: http://www.opw.ie/en/disclaimer/
Qgis-user mailing list
Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180808/910ca95b/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180808/910ca95b/attachment.png>
