[Qgis-user] Textual representation of styles ?
Andrea Aime
andrea.aime at geo-solutions.it
Wed Aug 8 02:49:57 PDT 2018
On Wed, Aug 8, 2018 at 11:44 AM Ville Koivisto <
ville.koivisto at kuntotekniikka.fi> wrote:
> *Hi all, *
> Appreciate your advice. If there are any more resources concerning this,
> please let me know. Exporting SLD file in QGIS seems to result in SLD 1.0
> file, without an option to influence the version.
How are you exporting? A native export from the style dialog should result
in a SLD 1.1 file, which GeoServer should read without issues.
If you are using the Boundless GeoServer plugin instead, yes, that has code
manipulating the style text and trying to make it turn into a SLD 1.0,
it's basically applying the same changes as described by Richard McDonnell
before in this thread.
I don't think it's being worked on anymore thought, the latest commit has
been done in 2017 and the latest release is over one year old:
https://github.com/boundlessgeo/qgis-geoserver-plugin
> Simple SLD tests seem to prove Andrea right. I’ve tried to implement a
> SLD style that has unique symbols for over 10,000 features. Apparently it
> is validated by Geoserver, but previewing the style on a file, I get
> nothing. I guess this kind of styling is simply too heavy or otherwise
> error prone?
I don't know. If you share the style I might get a clue about what's going
on (or not, we'll see!).
Cheers
Andrea
== GeoServer Professional Services from the experts! Visit
http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf
Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa
(LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180808/025a4226/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180808/025a4226/attachment.png>
