[Qgis-user] Textual representation of styles ?
Lars I. Nielsen, LIFA A/S
lin at LIFA.DK
Wed Aug 8 03:55:16 PDT 2018
Hi Andrea,
Exporting an SLD ”which GeoServer should read without issues” is not really true in all cases.
There a several smaller issues. E.g., we’ve just realized, that the “ElseFilter” is neither imported into nor exported from QGIS.
Med venlig hilsen
GIS konsulent, FME Certified Professional
T
6313 6800
lin at lifa.dk
D
6313 6849
W
www.lifa.dk
M
2492 4866
[Beskrivelse: C:\Users\lin\AppData\Roaming\Microsoft\signatures\21x21-Images-Get-L749-l8.png]<https://www.linkedin.com/company/lifa-a-s/>
Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S Landinspektører
Fra: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Andrea Aime
Sendt: 8. august 2018 11:50
Til: ville.koivisto at kuntotekniikka.fi
Cc: qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] Textual representation of styles ?
On Wed, Aug 8, 2018 at 11:44 AM Ville Koivisto <ville.koivisto at kuntotekniikka.fi<mailto:ville.koivisto at kuntotekniikka.fi>> wrote:
Hi all,
Appreciate your advice. If there are any more resources concerning this, please let me know. Exporting SLD file in QGIS seems to result in SLD 1.0 file, without an option to influence the version.
How are you exporting? A native export from the style dialog should result in a SLD 1.1 file, which GeoServer should read without issues.
If you are using the Boundless GeoServer plugin instead, yes, that has code manipulating the style text and trying to make it turn into a SLD 1.0,
it's basically applying the same changes as described by Richard McDonnell before in this thread.
I don't think it's being worked on anymore thought, the latest commit has been done in 2017 and the latest release is over one year old:
https://github.com/boundlessgeo/qgis-geoserver-plugin
Simple SLD tests seem to prove Andrea right. I’ve tried to implement a SLD style that has unique symbols for over 10,000 features. Apparently it is validated by Geoserver, but previewing the style on a file, I get nothing. I guess this kind of styling is simply too heavy or otherwise error prone?
I don't know. If you share the style I might get a clue about what's going on (or not, we'll see!).
Cheers
Andrea
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180808/a922bd88/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180808/a922bd88/attachment.png>
