[Qgis-user] Fwd: importing dwg
Andreas Neumann
a.neumann at carto.net
Wed Aug 15 01:19:59 PDT 2018
Hi Boaz,
Step 1 is not necessary. You can create a new geopackage directly from
the DWG/DXF import dialogue.
Please open a bug report at https://issues.qgis.org/ and upload your
sample DWG file.
Perhaps your file is broken or not supported by the library. I had files
in the past that did not work as well.
"The could not open layer list" perhaps indicates that it can't read the
DWF file, given that the path to the file was already filled in from a
past attempt.
Greetings,
Andreas
Am 15.08.2018 um 09:28 schrieb Boaz Bar Ilan:
> ---------- Forwarded message ----------
> From: *Boaz Bar Ilan* <boazprosie at gmail.com <mailto:boazprosie at gmail.com>>
> Date: 2018-08-15 9:35 GMT+03:00
> Subject: Re: [Qgis-user] importing dwg
> To: Andreas Neumann <a.neumann at carto.net <mailto:a.neumann at carto.net>>
> hi
> step 1 - I create geopackage layer in the admin directory
> step 2 - from project I choose - dwg/dxf import and a new windows open
> immediately a red line appear which says - couldn't open layer list
> step 3 - after few seconds the red line disappear but when im trying
> to import a dwg - nothing happen
> attached here screenshots of the step
> thanks
> boaz
> 2018-08-14 12:35 GMT+03:00 Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>>:
> Dear Boaz,
> You need to provide more information and a sample file if you
> expect help from us:é
> What exactly did you do (detailed steps)?
> What failed?
> Are there any error messages?
> Can you provide sample data that failed?
> Greetings,
> Andreas
> On 2018-08-14 11:13, Boaz Bar Ilan wrote:
>> hi
>> I follow exactly the instructions ( from the help contents )
>> but the dwg isn't being imported
>> is anyone that can help ?
>> im using 2.18.18 and win 10
>> thanks
>> boaz
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180815/68073bab/attachment.html>
