[Qgis-user] Fwd: importing dwg
Boaz Bar Ilan
boazprosie at gmail.com
Wed Aug 15 03:34:32 PDT 2018
hi
the red line with the " couldn't open layer lust" appear before I do any
import action with the dwg. so it cant be effected from the dwg file!!
I tries to import few files of dwg but it works on and off
boaz
2018-08-15 11:19 GMT+03:00 Andreas Neumann <a.neumann at carto.net>:
> Hi Boaz,
> Step 1 is not necessary. You can create a new geopackage directly from the
> DWG/DXF import dialogue.
> Please open a bug report at https://issues.qgis.org/ and upload your
> sample DWG file.
> Perhaps your file is broken or not supported by the library. I had files
> in the past that did not work as well.
> "The could not open layer list" perhaps indicates that it can't read the
> DWF file, given that the path to the file was already filled in from a past
> attempt.
> Greetings,
> Andreas
> Am 15.08.2018 um 09:28 schrieb Boaz Bar Ilan:
> ---------- Forwarded message ----------
> From: Boaz Bar Ilan <boazprosie at gmail.com>
> Date: 2018-08-15 9:35 GMT+03:00
> Subject: Re: [Qgis-user] importing dwg
> To: Andreas Neumann <a.neumann at carto.net>
> hi
> step 1 - I create geopackage layer in the admin directory
> step 2 - from project I choose - dwg/dxf import and a new windows open
> immediately a red line appear which says - couldn't open layer list
> step 3 - after few seconds the red line disappear but when im trying to
> import a dwg - nothing happen
> attached here screenshots of the step
> thanks
> boaz
> 2018-08-14 12:35 GMT+03:00 Andreas Neumann <a.neumann at carto.net>:
>> Dear Boaz,
>> You need to provide more information and a sample file if you expect help
>> from us:é
>> What exactly did you do (detailed steps)?
>> What failed?
>> Are there any error messages?
>> Can you provide sample data that failed?
>> Greetings,
>> Andreas
>> On 2018-08-14 11:13, Boaz Bar Ilan wrote:
>> hi
>> I follow exactly the instructions ( from the help contents ) but the
>> dwg isn't being imported
>> is anyone that can help ?
>> im using 2.18.18 and win 10
>> thanks
>> boaz
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180815/299664a0/attachment.html>
