[Qgis-user] vector tools of Grass failed in Qgis 3 Mac os
Mensio Federico
mensio at ipla.org
Tue Aug 21 03:07:03 PDT 2018
Its' seems a problem of Python. Some solution?
Algorithm 'v.clean' starting…
Parametri in ingresso:
{ '-b' : False, '-c' : False, 'GRASS_MIN_AREA_PARAMETER' : 0.0001,
'GRASS_OUTPUT_TYPE_PARAMETER' : 0, 'GRASS_REGION_PARAMETER' : None,
'GRASS_SNAP_TOLERANCE_PARAMETER' : 1, 'GRASS_VECTOR_DSCO' : '',
'GRASS_VECTOR_LCO' : '', 'error' :
'/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_8fc8a3cd9db144d8a7e04d741f6b2821/510564a2b8db42e393e2254640a879ae/error.shp',
'input' : '/progetti/temp/suoli_test.shp', 'output' :
'/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_8fc8a3cd9db144d8a7e04d741f6b2821/16c02a3f39974724bef28a376b3e63ca/output.shp',
'threshold' : '1', 'tool' : [0], 'type' : [0,1,2,3,4,5,6] }
g.proj -c proj4="+proj=utm +zone=32 +datum=WGS84 +units=m +no_defs"
v.in.ogr min_area=0.0001 snap=1.0 input="/progetti/temp/suoli_test.shp"
output="vector_5b7be41acf0d87" --overwrite -o
g.region n=5068419.991296747 s=4905848.379899999 e=521593.56898278
w=350249.30290076975
v.clean input=vector_5b7be41acf0d87
type="point,line,boundary,centroid,area,face,kernel" tool="break"
threshold="1" output=output10c76cc109c14eca860414df206c8505
error=error10c76cc109c14eca860414df206c8505 --overwrite
v.out.ogr -c type="auto" input="output10c76cc109c14eca860414df206c8505"
output="/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_8fc8a3cd9db144d8a7e04d741f6b2821/16c02a3f39974724bef28a376b3e63ca/output.shp"
format="ESRI_Shapefile" --overwrite
v.out.ogr -c type="auto" input="error10c76cc109c14eca860414df206c8505"
output="/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_8fc8a3cd9db144d8a7e04d741f6b2821/510564a2b8db42e393e2254640a879ae/error.shp"
env: python3: No such file or directory
Esecuzione completata in 0.64 secondi
Risultati:
{'error': <QgsProcessingOutputLayerDefinition
{'sink':/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_8fc8a3cd9db144d8a7e04d741f6b2821/510564a2b8db42e393e2254640a879ae/error.shp,
'createOptions': {'fileEncoding': 'System'}}>,
'output': <QgsProcessingOutputLayerDefinition
{'sink':/var/folders/_p/g0dpln352f7fw6mpryz77ddc0000gn/T/processing_8fc8a3cd9db144d8a7e04d741f6b2821/16c02a3f39974724bef28a376b3e63ca/output.shp,
'createOptions': {'fileEncoding': 'System'}}>}
Federico MENSIO
IPLA spa
Corso Casale, 476 - 10132 Torino
Mobile +39.340.06.01.363
TEL +39.011.432.0443 FAX +39.011.89.89.333
mensio at ipla.org - www.ipla.org
Questa e-mail è personale e i suoi contenuti contengono informazioni
riservate ai destinatari. Pertanto la lettura, copia od altro uso da parte
di altri o qualsiasi altra azione derivante dalla conoscenza di queste
informazioni sono rigorosamente vietate e perseguibili ai sensi del Dlgs
196/03.
Qualora abbiate ricevuto questo documento per errore siete cortesemente
pregati di darne immediata comunicazione al mittente ai riferimenti
indicati e provvedere immediatamente alla sua distruzione.
Salvaguardiamo l'ambiente: se non ti è necessario, non stampare questa mail
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180821/95b9a1c9/attachment.html>
